Results 1 to 3 of 3
Thread: Door Lock issue
    Apr 2022
    Oregon
    04 X3 and 11 328i Xdrive
    Door Lock issue
    Ok. I’m aware of the typical lock actuator failure. I have replaced the lock actuator with a new unit. Here is the issue. The door will only unlock with the key fob or central lock system. It has to be manually locked with the valet key. All the fuses are good, the lock actuator is good (I put two of them in and they both would only unlock). All of the other doors lock and unlock with the fob and central door lock button as they should. Any ideas?
    2011 328i Xdrive
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Valet Key or Main Key should give the same result, both of them must be inserted into the lock and turned.
    Since you replaced the actuator and the new one(s) have the same issue, then my money is on the body controller unit not sending out the signal on the wire, or the wire is broken.
    When you put the key into the lock, you are operating the actuator manually/mechanically, when you are pressing buttons or switches, you are operating the actuator electrically. You report the mechanics work okay, the electronics are bad. This tells me to go after the body module.
    Apr 2022
    Oregon
    Makes sense. Do you, or anyone reading this, have the schematics for the wiring at the door actuator? I can test if I’m getting power to the “lock” function, but I believe there are 7 pins and I don’t know which is which.
    thanks for the reply!
  1. middle vents and door lock issues with 1999 323
    By alpac in forum 1999 - 2006 (E46)
    Last Post: 12-02-2006, 01:31 AM
  2. Drivers door lock issue
    By e36m3_858 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-17-2006, 09:27 PM
  3. Door Lock Issue
    By callahan2006 in forum 1999 - 2006 (E46)
    Last Post: 04-25-2006, 01:04 AM
  4. door lock issue (drivers side)
    By jbreiding in forum 1988 - 1996 (E34)
    Last Post: 05-05-2005, 07:40 AM
  5. Door lock issue?
    By ShowTime 525 in forum 1988 - 1996 (E34)
    Last Post: 05-01-2004, 01:51 PM
