I am about to retire in the next year so my race car has to go. This is an all steel car with hand made front and rear fenders, custom fiberglass nose integrated into the front fenders. The mold for the front end goes with the car. Aerodynamics was a big focus. The kidney grills are just painted on limiting the air to the lower duct is set on the radiator. The front brakes are ducted and the intakes are in the former headlight holes. Much better than down low above the splitter. Don't have to disconnect to remove the front end, and no more clag getting the the ducts. Full cage with all rear suspension mounts tied in to the cage. Front end/splitter comes off with 4 Dzus fasteners so simple for loading on a trailer. The rear spoiler is attached with 4 easily removed pins so putting a cover on is easy, and if you have ever hit your head on the carbon fiber end plates you will really appreciate this. Motor was just rebuilt and has only been warmed up and leak checked. Has 12.5/1 pistons but using a Cometic head gasket to lower by about .5. I am currently running it on Sunoco 105 race fuel. At just under 2500 lbs, the monster contact patch and the aero on the car it is tremendous fun and very forgiving. The light weight means tires and brakes last longer keeping expendables down. The car is very well balanced but may show a little oversteer at times. Majority of the suspension is less than 3 weekends. The car is painted with an acrylic enamel so easy to repair scratches. I could go on and on. The deal is the race car, the trailer, front end fiberglass mold and a set of unused rains for $34,000. I have a clear Texas title for the car and trailer.
Body/Chassis
1992 E36 325i 4 Door Sedan
NASA log book
2480 lbs w/7 gallons of gas
Custom Rear Flares (Steel)
Custom Front Fenders (Steel)
Custom Front Fascia with Splitter to c/l of Front Axle (removes easily w/4 Dzus)
Includes the mold for the fiberglass front end
10 Point Cage- all suspension points tied-in (main bars 1.5” .120 wall)
PowerFlex Rear Subframe Bushings
3.38 LSD in Car- 2 clutch replace 2 weekends
Also includes 3.91 LSD 3 clutch 4 weekends
True Side Exit Exhaust-Tunneled (Magnaflow) on passenger side (very smooth undercarriage) super light, sound great.
Master Electrical Cut-Off Switch
Custom Aluminum Dash w/Memory Tach
Autometer gauges (Water Temp, Oil Temp, Oil Pressure, and Cylinder Head)
6 25 amp Re-settable Breakers on Dash
Push Button Start
Bimmerworld Steering Wheel Quick Release
Steering Column lowered
CoolShirt System
Suspension
AST Shocks- 2-way front/ 3 way rear adjustment.
Hyperco Springs
Vorshlag Camber Plates
Ground Control Spherical Rear Trailing Arm Bearing
Rear Upper and lower Inner Spring Arm Bearings, Ground Control
Front M3 Spindles and Bearings
BimmerWorld E36 Race Front Control Arms/roll center correcting
BimmerWorld AN Power Steering Kit
Front Control Arm Bearings, Offset, BimmerWorld-Spherical front bushing
BMW Motorsports Tie Rods/Bump steer Adjusters
Front Brake Cooling Hose plates
Engine
New S50 Race Engine - only warm-up time
12.5/1 JE Pistons and rings (5mm overbore)
Maxpeeding H-Beam aluminum rods
ARP fasteners on Rods, Mains and Head Studs
New AMC Cylinder Head - Port matched on exhaust side
SuperTech race springs w/steel retainers
24 lb Injectors
Bimmerworld Silicone 3.5” Intake boot
Euro 3.5” HFM MAF
Silicone upper and lower Radiator hoses
Mishimoto Aluminum Radiator
16” Spal Pull Fan
Custom Aluminum Radiator to Bumper Shroud
7.5” Tilton single disc/flywheeel combo
Vorshlag Race Engine/Trans Mounts
Dr Vanos Single-Vanos
Safety
Ultrashield Window Net
Ultrashield 15” Seat on custom mount
Auto power Seat Back Brace
Ultrashield 6 point belt
6 power circuit switches w/ reset able breakers
Rear View Camera
Brakes
Converted to full M3 Brakes
Front Rotors (new)
Stainless Brake Lines
Front brake cooling
M3 Master Cylinder
M3 ABS ECU (Spare Included)
Wheels/Tires
2-315/18 on Arc-8 10.5x18 Hoosier A7
2-285/18 on Arc-8 10x18 Hoosier A7
4-275/18 New Hoosier wets on D-force 10x18
Price reduced to $28,900
Need to sell so make me an offer
Lowered to $ 25,900
