Results 1 to 25 of 25
Thread: X brace - new or used
    Jun 2021
    New York
    E36 M3
    I’ll probably add the x brace to further reinforce the subframe. Seems like it offers minor improvement in handling dynamics, but minimizing subframe flex seems to be worth it.
    My question is, does it matter if you buy new or used for the x brace? Seems to just be a piece of metal bracing. Wondering if it’s prone to warping or flexing if buying used?
    Aug 2012
    Central, MD
    1995 M3
    Used is fine. It's as likely to be bent as any other subframe part. That is, very unlikely unless in a nasty crash.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Unless there is something very weird about BMW (there is, on many places), it should be fine, unless the donor car has been crashed.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    There are zero issues with good used braces. You do have to look out for bent ones due to accidents though. I’ve run across a few in the two dozen I’ve had over the years.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Used ones are great, no real reason to get new.
    Make sure your front subframe has the inserts with threads for the fasteners though! I think some cars ('95?) didn't have them, but not completely sure on which year(s).
    KC
    1995 M3 & 1998 M3 coupes
    I got a few in the past from the local pick n pull. One of the older style and one of the newer design that didn't block the oil drain bolt. At least I think that was the reason for the change. I think I paid $14 dollars for each of them. Still need to install one of them and give the other to a friend of mine.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Quote Originally Posted by golgo13 View Post
    My 10/94 build 1995 model had the inserts in the frame. And I’ve heard of 9/94 builds also having them. So I think it was the earlier 1994 builds (through June/July?) that didn’t have them.
    -rb
    Jun 2021
    New York
    E36 M3
    Just confirming, same part/fitment for E36 M3 and Z3?
    Oftentimes these are cross listed as a Z3 part without a part number.
    Jun 2021
    New York
    E36 M3
    Quote Originally Posted by E85STI View Post
    I got a few in the past from the local pick n pull. One of the older style and one of the newer design that didn't block the oil filter. At least I think that was the reason for the change. I think I paid $14 dollars for each of them. Still need to install one of them and give the other to a friend of mine.
    If your friend doesn’t want it, I’ll gladly take it lol
    Long Island, NY
    1995 M3 - 2007 X5
    Blocks the oil filter? The X-brace is underneath the vehicle.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by ChuckDizzle View Post
    Oil drain plug he probably meant
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    KC
    Quote Originally Posted by ScotcH View Post
    LOL, yeah I meant the oil drain plug not the filter.
    The Netherlands
    DE-spec E36 328i/M3 cab
    The Z3 version is 99% identical to the M3. They all fit either model.
    The Z3 version comes with an extra plate welded on, where a stop buffer is fitted. This sit nearly against the oil pan and limits the amount the engine can tilt to keep the drivetrain aligned.
    The later model with offset cross is the one you want if you want to fit the OEM EU undertray. This has a cutout for the offset brace.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Now if you want to be extra fancy, get one of the aluminum plates from the early OBDI E36 convertibles like I have.
    Aug 2012
    Central, MD
    1995 M3
    Wowa! Didn't even know those were a thing.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by aeronaut View Post
    I ran across it on Craigslist a few years ago and had to look it up. It's a couple pounds lighter than the steel x-brace so I thought, "Why not?" since I'm always looking to shave weight where I can for road racing.
    The Netherlands
    If it's from aluminium it will bend like Swiss Cheese in case of an accident or other impact.
    The part comes back for the E36 Touring model only when looking it up.
    Also listed as "Cover", not "Reinforcement", which makes sense if it's from alu - see my first sentence.
    IG:
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by MParallel View Post
    That makes sense, which is why I try not to hit things with my car.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    e46 and e90 M3 "cover" is aluminum. I don't think any of them are meant to take a hit. it's to stiffen and reinforce the side loads on the chassis
    The Netherlands
    Maybe they function differently in the way the forces are applied and the way they are mounted?
    IG:
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Me too, but I've made contact a couple times over the years with really badly rutted roads. I shudder to think about the consequences if I hadn't had my x- brace installed.
    KC
    I have to echo I didn't know this aluminum cover/brace even existed!
    Mar 2003
    somers,ny
    nice find there!!!!
    Oct 2003
    Seattle
    99 M3
    I have to wonder if there is a slight aero benefit.
    Oct 2020
    PNW
    1995 US e36 M3 Coupe
    it's one of those odd things that go with early 95 builds. not sure of the month, but my guess is it tracks with other updates like the seats, steering wheel tilt, fuel pump location, a few others. i think the change is mid year, maybe june or july.
    my 10/95 has the inserts already installed.
    [ US spec 10/1995 e36 m3 ]
  1. new or used x-brace
    By xlDooM in forum 1991 - 1999 (E36)
    Last Post: 02-08-2016, 11:52 AM
  2. WANTED: E36 M3 X-Brace/New or Used
    By Bstone in forum BMW Parts Wanted
    Last Post: 06-10-2006, 04:20 PM
  3. FS Brand new never used BMW OEM stock cd changer for 96+
    By rollinondubs in forum BMW Parts For Sale
    Last Post: 05-06-2002, 12:06 PM
  4. New Or Used M3
    By HK_M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2002, 03:05 PM
  5. INDIGLO, part new, part used, only $20 shipped!
    By Bernanke in forum BMW Parts For Sale
    Last Post: 03-22-2002, 11:46 PM
