Results 1 to 5 of 5
Thread: Engine Starts when cold-dies in 2mins. when warm 1984 533i
    Mar 2022
    california
    e28
    Replaced the Engine coolant temp sensor, Thermo-time switch, Coolant temp sender and radiator switches (top and bottom).
    I just ordered an Idle controls temp switch and its on the way New thermostat and silicon hoses and fan clutch.
    cleaned out the fuel injectors, spark plug replaced and new plugs (did not change distro cap and rotor).
    the car starts right up but dies after 2 minutes. it wont start again until the engine is cold.
    what is going on? anyone got any ideas on what is failing?
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    I had a coil that was over heating leading to the engine dying after it warmed.
    Andy
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    I don't know the details on that model, but I wonder if it works on open loop and then not on closed loop.
    Mar 2022
    california
    e28
    thank you...
    Quote Originally Posted by south42 View Post
    Andy
    I will look for one to replace it. I feel like that is a better answer than what -heyy, I found some literature that supports what you are saying! thanks.:
    Well, there is an ignition problem that can cause this when the engine gets hot and it stalls. It'scaused by a lack of spark which can be either the ECU's fault (on EFI cars), or the coil on prettymuch any car.Heat causes expansion. The ECU or the coil gets hot and expands. This expansion can separate afine / broken circuit inside causing it to not be able to conduct the electric signal that tells the coil tospark, or it could be inside the coil and it simply can't deliver any spark even if the ECU is telling itto. In this situation, you can usually re-start the engine once it has had a chance to cool back downand it'll run just fine until it warms-up again and stalls. This is a tell-tale sign that there is a hair linefracture in the ECU's circuit or in one of the coil's windings that separates and loses connectionwhen it gets hot and expands.
    Mar 2013
    USA
    E21/early e23/e34
    I recommend you purchase a Bentley manual and get familiar with the car. It will make your life soooo much easier. It could be a number of things and the Bentley will help you test the different components.
    Having said that, the coil does sound reasonable but I've only had 2 go bad.
  1. Engine started sputtering and dies, then is fine, what gives?
    By jays325is in forum 1983 - 1991 (E30)
    Last Post: 07-24-2012, 03:46 PM
  2. Engine starts then immediately dies
    By Mike Bonkalski in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 02-25-2008, 07:43 PM
  3. Help! Engine starts and then dies!
    By MikeE36 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-27-2005, 09:46 PM
  4. What is this cold engine start problem?
    By LIL RAJA in forum 2001 - 2006 M3 (E46)
    Last Post: 06-10-2003, 09:01 PM
  5. engine sound when cold start help
    By M3corey in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-17-2002, 03:03 PM
