Results 1 to 7 of 7
Thread: e36 m3 s54
    sf
    e36
    e36 m3 s54
    price lowered to 25000 from 30000 for quick sale
    1997 bmw m3 alpine white, 220 miles on chassis, estimated 5-6k miles on motor.engine info:
    s54 full rebuild
    ngk spark plugs
    bosch oem ignition coils
    bosch oem alternator(new)
    valve cover gasket
    valve adjustment
    complete besian vanos kit(seals,oil disc,upper chain guide,vanos solenoid)
    new crankshaft bearing oem
    wpc coated bearings
    arp rod studs
    arp head studs
    oem headgasket
    spa technique oil pressure,temp sedner and gauges
    bimmerworld vanos line
    bimmerworld moroso aluminum expansion tank
    setrab oil cooler
    turner motorsport oil cooler fitting
    custom an oil lins fitting to front kidney grill
    suspension info:
    ground control single adjustable coilover 600lb/850lb
    vorshlag camber plate
    ground control front and rear sway bars and endlinks
    rear strut bar
    synchro design spherical solid rtabs
    akg 75k subframe and diff bushings
    akg 75d engine mounts
    rough engineering tranny mounts
    drivertrain info:
    80k miles zf 5speed transmission
    new oem clutch and jbl flywheel
    new pilot bearing and new detents rebuilt in tranny
    3.73 lsd built by wanganstyle
    new gsp rear axles
    wheels info
    replaced all 4 wheel bearings and new hubs
    apex 90mm studs
    apex arc8 17x9.5 wheels
    bridgestone re71r 255/40/17 tires
    brakes info:
    full e46 m3 csl abs system conversion
    teves mk60 dsc 3 (ate pn 10.0960.0813.3) reflashable to csl
    new oem e46 m3 speed sensors x4
    z3m brake booster
    e46 m3 master cylinder
    stainless steel brake and clutch lines
    ap racing front bbk, pfc 11 20mm pads new pads
    dtc60 rear pads with rebuilt rear calipers, centric rear new rotors
    other misc stuff
    dtmfiberwerkz fiberglass hood
    ltw style wing
    bimmerworld front splitter
    euro 3 spoke steering wheel
    mss54hp ecu , currently running hte performance tune
    z3m s54 clutster
    cae shifter with akg dssr
    spa oil gauges and stack oil pressure gauges
    recaro driver seat
    vac mounts
    radiator ducting.
    striped down for weight reduction.
    ac has been removed(still have the complete ac system that can put back)
    carpet removed and sound deadening ( still have the carpet as well on storage)
    heater still on the car and works
    Photo 1 : https://imgur.com/a/YzIK815
    Photo2: https://imgur.com/a/fIRRgau
    https://i.imgur.com/bGr7aYi.jpg
    https://i.imgur.com/otL3H3X.jpg
    https://i.imgur.com/prPCMez.jpg
    https://i.imgur.com/FC6Vnu4.jpg
    https://i.imgur.com/xNnu4gB.jpg
    https://i.imgur.com/qDmauyH.jpg
    https://i.imgur.com/dIkxdFv.jpg
    https://i.imgur.com/IFSlk91.jpg
    https://i.imgur.com/i4I2mm3.jpg
    https://i.imgur.com/Mufzt2K.jpg
    https://i.imgur.com/oUYcure.jpg
    https://i.imgur.com/Yy2SYkk.jpg
    https://i.imgur.com/siLTiVQ.jpg
    https://i.imgur.com/oG7KgX9.jpg
    https://i.imgur.com/3TjMtWO.jpg
    sf
    e36
    Price lowered for quick sale
    Feb 2016
    Rogers AR
    1995 BMW M3
    Quote Originally Posted by masaki87 View Post
    Pm sent
    Mar 2010
    NJ
    E39 540i, E46 M3, E36 M3
    This car has been up for sale for so long, why?
    Jan 2005
    New Jersey
    1995 Dinan Supercharged M3
    Its hard to move track spec cars. PM sent.
    sf
    e36
    bump
    Sep 2022
    Bay Area
    99 E36 M3 Track Car
    Hi There - is this still for sale? Thanks
  1. E36 E36 m3 s54 track build
    By masaki87 in forum 3 series & Z Series
    Last Post: 01-20-2022, 05:51 PM
  2. E36 4/94 BMW E36 M3 S54 SWAP Performed by Max Psi
    By GG///M3 in forum 3 series & Z Series
    Last Post: 11-29-2016, 06:20 PM
  3. E36 4/94 BMW E36 M3 S54 SWAP Performed by Max Psi
    By GG///M3 in forum Race Cars & Track Parts
    Last Post: 05-21-2016, 03:33 PM
  4. E36 feeler - e36 M3 s54 Track/Race car
    By kenshin223 in forum Race Cars & Track Parts
    Last Post: 01-11-2013, 01:19 PM
  5. E36 WTB: 95 E36 M3 S54 6speed
    By omak81 in forum BMW Parts Wanted
    Last Post: 06-16-2011, 10:29 AM
