So I have my 82 E21 5spd m10 1.8l that I've had stored at my parents for the last 10+ years. I can't seem to find the driveshaft for it, it's literally nowhere to be found even though I know I had it stored somewhere. I do however have a parts car which is a 1.8l automatic. My question is, can I use the automatic drive shaft for the manual transmission? Is it the same? If not what's the difference? And is there any way I can make it work??? Any help would be much appreciated. Thanks
I think that the automatic driveshaft is shorter than the manual, I may be wrong on that though.
I could probably send you a 5 speed drive shaft. Where are you?
Sent from my Pixel 5a using Tapatalk
For the '82 model years, the driveshaft part numbers are different for an automatic and manual transmission.
