Results 1 to 13 of 13
Thread: S50b32 Fault Codes
    Mar 2022
    Southwest
    S50b32 swapped e36
    S50b32 Fault Codes
    I have a '95 M3 with an Euro S50b32 swapped. Using a Foxwell scanner I'm getting the following codes, but cannot find out what they mean:
    8a DTC -DME: DMS Digital Motor Electronic: fault stored
    2a DTC -DME: DMS Digital Motor Electronic: fault stored
    42 DTC -DME: DMS Digital Motor Electronic: fault stored
    35 DTC -DME: DMS Digital Motor Electronic: fault stored
    12 Instrument Cluster code 20 DTC Ignition Key Contact Operation not plausable
    The car fires up and idles just fine, but during moderate acceleration I can hear a "wha, wha, wha" as the engine revs. I hope that understanding what those codes means, I can chase down what is causing that noise.
    Thanks for your help!
    Oct 2016
    Austria
    e36 323i, M3 3.2
    S50B32 is an engine found in european spec cars, which usually have a 20pin round BMW connector in the engine bay. If your car has such a connector then get a cable and the software to read codes through that, it will give a more detailed code description.
    Mar 2022
    Southwest
    S50b32 swapped e36
    I have the Schwaben by Foxwell BMW/MINI Scanner 14020SCH with the 20 pin adapter and those are the codes that showed up. I am struggling to find any resource or software to interpret what those codes mean.
    Oct 2016
    Austria
    e36 323i, M3 3.2
    If nobody can tell you what the codes mean and you can't find it using google, then I don't see another option besides trying INPA and hoping it can give you more information.
    Also, INPA can provide more engine data and values that could help diagnose your problem.
    Jun 2010
    NY
    1997 328i
    I think you should use INPA, software is free in the z3 diagnostics forum. Get the cable off eBay or Amazon.
    Apr 2015
    Tennessee
    1998 BMW 328i
    Google showed the following:
    8a code was related to body control module
    2a code was a speed sensor
    42 and 35 were related to the dsc stability system.
    Not sure how accurate these are, take it with a grain of salt.
    Sent from my SM-G975U using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 M3 forum from E36 forum
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Do you feel a hesitation during acceleration or is it just a noise? Was the vanos ever rebuilt?
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by shogun View Post
    Why not into the Euro specific sub?
    IG:
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by MParallel View Post
    Done.
    88M3 AW 43k miles Project FS
    The Netherlands
    Quote Originally Posted by MauiM3Mania View Post
    Done.
    *like*
    IG:
    Mar 2022
    Southwest
    S50b32 swapped e36
    The VANOS seals were replaced 10k miles ago. There is a slight hesitation during acceleration when that noise is present and then the noise disappears when holding a constant speed.
    I appreciate everyone's comments and helps as I chase this issue down.
    Jan 2002
    Central Pacific
    I have nothing to add but am curious what sort of mileage is on the engine.
  1. E5 Fault Code/Check Engine Help
    By FaRTaLOTTT in forum 1992 - 1999 M3 (E36)
    Last Post: 01-26-2002, 03:16 AM
  2. Camshaft Sensor Fault Code
    By NicolasW in forum 1992 - 1999 M3 (E36)
    Last Post: 09-08-2001, 02:48 PM
  3. Built in Fault Code Reader!!
    By Mike325i in forum 1991 - 1999 (E36)
    Last Post: 08-23-2001, 08:36 PM
  4. WTB: Peake Research Fault Code reader w/ manual
    By Lopaka in forum BMW Parts Wanted
    Last Post: 06-29-2001, 01:46 AM
  5. DME fault code: EGO Sensor #1??
    By ///Arman in forum 1991 - 1999 (E36)
    Last Post: 05-29-2001, 07:56 PM
