This has been bugging me for 30+ years. That I cannot turn my fogs on with just the parking lights.
So, I presented this to my friend Jody, an electrical Guru and he came up with an easy solution.
The only drawback is when the headlights are switched to high beams, the fogs don't shut off.
I have no problem with that. The fogs will work with park or low & high beams.
If anyone is interested in this conversion, we can supply the conversion harness, schematic
and instructions. This would work for all Bimmers that use the same system as the E24 era cars.
So, let me know if this is a conversion that you would be interest in?
I've made a correction:
If you don't mind that the fogs are still on with high beams no harness required. Will there be too much electric draw?--I don't know, maybe. Or just turn off the fogs in high beam position. Or, a harness and SPDT switch will be required from the fuse box to dash.
Bob V
