Results 1 to 8 of 8
Thread: Lean codes bank 1 and 2
    Sep 2020
    Orange County CA
    E39 touring
    Having a headache for months trying to
    figure out the lean codes on my 2002 E39 wagon.
    P0171 and P0174. Did replace the CCV,valve cover gasket, valve cover
    No leaks from the smoke test, no loss of power. Don’t know what else to do.
    Nov 2018
    La Habra, CA
    2002 525i
    Sometimes a flakey MAF will cause lean conditions, especially if they show up in both banks.
    Current stable:
    2002 525i (Daily Driver)
    1994 SN95 Mustang 'Vert (The Bumblebee)
    2001 325i Convertible (Beach cruiser project)
    Jaaap is offline ☀ ☁ ☂ ☃ ☏ ☠ ☢ ☣ ♕ ♫ ✂
    Jun 2008
    Belgium
    Alpina B10 e39 / F3
    Check the fuel pressure.
    If it is ok, check how fast it can recover to the correct pressure when you let the pressure off.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    That ^^
    Also replace the fuel filter/ regulator if you have never done it on this car
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    On these cars you have to smoke test the crankcase too. A leak there can cause unmetered air to enter the intake through the PCV system.
    Jul 2017
    Turkey
    '00 540i M-Tech
    your cats are probably clogged.
    Jan 2022
    Savannah, GA
    2001 BMW 530i, e39
    I also has this same issue for months if not longer. Then I started to pop my transmission fuse. That was just another issue in a series if issues. However, I discovered my transmission fuse is linked to O2 sensors. So I checked around them again and traced the wiring in its protective jacket behind the block, (where I could only feel instead of see) I ran my hands down one of the O2 sensors wiring. Something felt awfully wrong back there. I fished out and found about 10 inches of wire that was fused together due to heat (and probably age) My e39 is a 2001. The wire was so bad, stiff as if it was a piece of iron and cracked exposing bare wire, clearly causing issues with my O2 and now popping my Transmission fuse. After cutting out the damaged wire and splicing the ends together, my transmission issues solved, O2 issues with bank 1 and 2 showing lean also solved, and so on. Check your wiring....
    May 2016
    Gresham, OR
    2001 BMW 530i
    I had the same codes, replaced the usual suspects like you did thinking it was a vacuum leak, etc. This time my valve cover was leaking oil, so it had to be replaced anyway, but I still got the codes after replacing it. I had occasional rough cold starts, too, so I cleaned my ICV and throttle body (They may never have been cleaned in 195k miles, they were both dirty). Codes haven't come back, and it's been a few hundred miles and many starts. It didn't cost me anything to clean them, just the time and hassle of getting to them. I could imagine how if one or both were sticking then it would cause the wrong amount of air to get to the engine and cause lean codes. The car idles better on cold starts, and seems to accelerate smoother.
  1. Lean code bank 1 and 2 help, please
    By SseeDragon in forum 1992 - 1999 M3 (E36)
    Last Post: 09-21-2019, 01:41 AM
  2. Lean codes - both banks - no leaks? appreciate ideas
    By raudi1 in forum 1996 - 2003 (E39)
    Last Post: 11-04-2018, 11:02 AM
  3. Replies: 18
    Last Post: 11-09-2015, 04:07 PM
  4. Does anyone else get a Bank One Too Lean Code
    By armiller1 in forum 1995 - 2001 (E38)
    Last Post: 01-19-2015, 11:50 AM
  5. Left Bank Lean code???
    By Nohopeboy in forum 1988 - 1996 (E34)
    Last Post: 06-30-2006, 10:54 AM
