I've searched for ages to find a nicely fitting one but the shops around here don't have them, can't even find a copper one just thin aluminium.
Currently everything is installed so I can't just take it all off to measure it sadly. Does anyone know the size of number 20 in this diagram? https://www.realoem.com/bmw/enUS/sho...diagId=32_0680
Or even the part number, that would be amazing!
The pump is a luk lf68 btw.
what is the complete VIN?
Wbahk41040gk00774
btw didn't get a chance to install your chip yet Shogun, a Subaru offroad project got in between but it's "done" now
Three different sizes pretty much cover all the banjo bolts found on these cars. You can determine which knowing the wrench size.
19mm wrench size uses a 14 x20 ring, 22mm uses 17 x 22.5 ring, 24mm uses 18 x 24 ring
# 19 is Hollow bolt M18X32 32411117183, in your ETK for the E34 the gasket is not shown, but the bolt is used on many BMW and there it says
04 2x Gasket ring A18X24-CUSN 32411093598 https://www.realoem.com/bmw/enUS/sho...94#32411117183
https://www.realoem.com/bmw/enUS/par...&q=32411117183
BMW FISCHER & PLATH Seal Ring - Power Steering Lines (18 X 24 X 1.5 mm) 32411093598 530i, 540i, 740i, 740iL
Thanks a lot guys! Ordered two copper 18 x 24 x 1.5 mm rings and will install them when I can put the car on the trench.
