eBMWParts
Results 1 to 3 of 3
Thread: 1998 323is rear spring advice
    May 2021
    Dana Point
    1998 BMW 323is
    I got a 1998 323is that I recently installed the Bilstein B14 PSS coilover kit on. My problem is that when i lower it to the ride height that i want, the rear springs are too soft. Even when it’s just me in the car the tires rub in the wheel well going over small bumps. (I have already rolled my fenders.) My question is does anyone know if there are other stiffer springs i can buy that will work with the B14 set? Any advice is appreciated, thanks y’all.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Maybe the ride height you want is too low for the B14 PSS kit you bought? The springs don’t get softer when you lower the car.
    What is your ride height?
    -rb
    Aug 2011
    Los Angeles
    my brother's ti
    you can put any e36 spring you want in there but your shocks are valved for a certain spring rate. I would do some research and find the spring rate for the springs you have then run something stiffer but close to your current springs. I have had luck going from 8k to 12k springs on the same pair of shocks(adjustable) with no negative affects. swift springs are the only springs i would use on an e36.
  1. Wanted: stock 323i rear springs
    By cgifool in forum 1975 - 1983 (E21)
    Last Post: 01-20-2019, 05:56 PM
  2. 1998 BMW 323is Rear Springs Question
    By Kilk428 in forum 1991 - 1999 (E36)
    Last Post: 01-18-2017, 05:14 PM
  3. will 1998 m3 rear springs fit my '95 325i?
    By heather in forum 1991 - 1999 (E36)
    Last Post: 03-24-2012, 08:00 PM
  4. rear spring advice
    By uk525td in forum 1988 - 1996 (E34)
    Last Post: 02-15-2012, 09:09 AM
  5. 1998 323i rear speakers
    By Resetg in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-26-2010, 04:16 PM
