I dropped a valve on my track focused S52 and have decided to just go the S54 route instead of rebuilding an S52. Have a lot in this motor over the past 8 years, my loss is your gain!
Original motor had 133k, a lot of the go-fast parts have <10k miles on them and I should even have original receipts. Located in Columbus, OH area, will work to get this updated with pics and additional detail. Feel free to ask about any other parts.
Google Drive with pictures: https://drive.google.com/drive/folde...BC?usp=sharing
- VANOS, just resealed with the Beisan kit and VAC limit spacer for big cams. Can remove the spacer if wanting to use with OEM cams: SOLD
- OEM Oil Pan with VAC baffle tig welded in, drain plug threads are good: SOLD
- OEM Oil pump pickup with arm gusset reinforcements: sold
- OEM Oil pump with safety wire nut: sold
- Schrick VAC 276/270 cams (these have <1000 miles on them) with splined VANOS shaft: SOLD
- OEM S52 cam trays and caps: $550
- OEM S52 MAF: sold
- Bosch 993 MAF from Bimmerworld (<1000 miles): sold
- Bosch 24lb injectors (new, not rebuilt) from BW (<1000 miles): SOLD
- OEM 21lb injectors (recently cleaned and flowtested): sold
- M50 manifold: sold
- M50 manifold silicone install/adapter Bimmerworld kit: sold
- S52 Supertech springs (<1000 miles): SOLD
- Hydraulic lifters from Achillies (8 new in packaging, 24 with <1000 miles): SOLD
- Cometic head gasket 0.080" (<1000 miles): $125
- ARP head stud kit (<1000 miles): sold
- S52 headers + SAP block off plate + o2 sensors + install hardware (<1000 miles): sold
- Bimmerworld E36 long tube header y-pipe: SOLD
- OEM oil filter housing: $50
- OEM plastic valve cover + studs (rubber gaskets have <1000 miles): sold
- Bremi ignition coils (<20k miles): sold
- S52 timing chain tensioner: sold
- DME with 3 tune files: (1) stock, (2) EWS delete, SAP delete, rear O2 delete, M50 mani, CAI, 3" exhaust, (3) same as 2 but also 276/270 cams, 993MAF, 24lb injectors: $900 (need to talk to Randy and confirm support for this)
- S52B32 spare block in good condition, needs re-honed/painted, unknown mileage: $500
- Misc OEM pistons, conn rods, water pump, alternator, cam gears, etc
Thanks,
Eric
I have some used arrow S52 rods and CP pistons to help out if someone is looking for a whole rebuild kit. Also I'm down in Louisville, Ky and done a few of the swaps if you need a hand.
Quality BMW service "street, track, race"?
Email: ZakspeedRacer@gmail.com
1999 BMW 318Ti/M Hellrot Msport DD/Fun car
1/2 1987 BMW 325is/M Future Spec e30 (track prep'd)
1994 530It/A Alpinewise III Traded out
1988 BMW 325ix/M Diamond Schwartz Recently sold :/
1986 BMW 325e/m Bronzit Beige Metallic
Get Involved!
www.bluegrassbimmers.org
OKI BMW Facebook group
BMWCCA Member# 436428
PM sent.
All PM's replied to.
2008 E92 M3 6MT - Mine
2017 F85 X5M - Hers
2003 E39 M5-S2 - Ultimate Family Sedan
1998 E36 M3 5MT - Track Rat
Pmed
Sent from my SM-G975U using Tapatalk
PMs replied, added Google Drive link with pictures as I start to add them
2017 F85 X5M - Hers
I think I have all PM's replied to, if I didn't please remind me to reply
2017 F85 X5M - Hers
i am interested in m50 manifold kit if you can ship usps to canada (toronto)
Pm sent. interested in con rods
let me know
PM sent about oil pan.
updated list with more sold items, still on the hunt for an S54
2017 F85 X5M - Hers
Interested in the plastic valve cover - sending PM
Thanks Rsanten nice chatting BMW's with you yesterday!
2017 F85 X5M - Hers
Bump. I have an S54! Actually an entire wrecked E46 M3 with 6MT I'm selling off as well. MOTIVATED TO GET S52 PARTS OUT OF MY GARAGE!!!
2017 F85 X5M - Hers
Still have S52 stock pistons? Looking for 2. Thanks!
Can't PM you as you just joined, but I put pictures in the Drive folder linked in the 1st post here. Pistons come with used rings, I don't have a full set and not sure what you're trying to (re)build but my advice would be to size your cylinders and buy a fresh set of 6 off of that. If you're able to PM me, send me your cell and we can chat.
2017 F85 X5M - Hers
