Morning!
I have a 2004 BMW E60 530d, and ofc it has abs issues. The front left connector, for the wheel speed sensor, is gone.
There is 4 wires, a Yellow, brown, red/blue and red. The red/blue and red is twisted together.
I cant find any wiring diagrams for the E60 anywhere. Im trying to solder a new sensor in All help is much appreciated
Sendt fra min SM-N986B med Tapatalk
Update:
I managed to find and solder the correct wires! But now im getting handbrake, abs and traction control light after 2min drive!
Have you checked to see what codes you are getting with regards to the ABS ?
start the car then rotate the wheel all the way left and then all the way right to see if that clears the code
