Results 1 to 1 of 1
Thread: Weird fault code
    May 2018
    EU
    2016 X3 & 2016 X1
    Weird fault code
    Please tell me if you ever encountered this fault (discovered at the shop randomly, at a routine inspection) that left them baffled, they said, quote "we never saw this code before".
    The code is as per picture attached, and it's described "engine speed monitoring difference between camshaft and crankshaft too high"
    They basically said that if that were true, the car would run like absolute shit, as the timing chain would be out of place, also it should not start at all if one of the sensors was kaput. But the car runs perfectly fine, starts fine, all is well, I would have not known about this unless they didn't read the codes, no CEL, no nothing.
    They advised I should do a firmware update at the dealer at the as they suspect it's a software issue/glitch, not a real problem.
    It's a 2016 X3 B47 2.0 diesel xdrive.
    edit: the mileage is in Km.
  1. WEIRD fault code: 93B5
    By eschapiro in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-16-2011, 05:28 PM
  2. Fault Code, and weird issue
    By MR E30 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-17-2010, 01:28 AM
  3. weird fault code message
    By robmpulse in forum 1999 - 2006 (E46)
    Last Post: 08-09-2010, 02:51 PM
  4. the e46 325i and the case of the weird fault code
    By hairy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-14-2005, 07:30 PM
  5. Built in Fault Code Reader!!
    By Mike325i in forum 1991 - 1999 (E36)
    Last Post: 08-23-2001, 08:36 PM
