Results 1 to 10 of 10
Thread: Bad IHKA panel?
    San Jose, CA
    1997 BMW 540i 6 speed
    Bad IHKA panel?
    It’s a ’97 540i. The IHKA “Auto” setting seems not to work: just a whisper of heat, and blower does not run. I can control the blower speed at the panel, and heat comes out, so I assume that the FSU is OK.
    The outside temp reading is correct.
    Any opinions that the IHKA control panel is faulty? I have not read a symptom like this.
    Dec 2019
    København
    1999 e39 520iA
    Quote Originally Posted by edjack View Post
    Inside the right vent, under the cold button , there is a inside temperature sensor and a fan that pulls the outside(cabin) air in and according to that reading the temperature is adjusted and heat is mostly directed to the feet.
    Usually it gathers huge amounts of dust and the sensor can not properly read the temperature.
    Also don't put any cold or worm in front of that vent in the cup holder. It will mess up the reading.
    Take a look here.
    https://youtu.be/W_-Q7ITIPvU
    Sent from my SM-G986B using Tapatalk
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Yep, old problem. I have had huge amounts of dust build up in that little pass through vent. The circuit board has a little fan that sucks air in from the cabin, samples the air and adjusts the climate control accordingly, little dustballs like to build up in there, vacuum those ports at least once a year.
    San Jose, CA
    New symptom for me. Just posted this to see if anyone else has observed it.
    NW suburban Chicago
    hiss by my window
    Any resolution for this? Another thought is that the aspiration fan has failed.
    San Jose, CA
    Is that the fan inside the IHKA panel? If so, I can hear it running.
    Feb 2014
    Alexandria, VA
    It can be running, but if there is the usual dustball in there, the sensor will not smaple the air properly.
    Oct 2018
    Hackensack, NJ
    99 528i, 90 535i, 07 X3
    If you have INPA and a cable you can talk to the IHKA and check the values at all of it's sensors.
    Dec 2019
    København
    1999 e39 520iA
    Did you check that video... you have all you need there, explained nicely.
    San Jose, CA
    I did watch it but have not yet embarked on the fix.
  1. Anybody got bad door panels?
    By bmx325i in forum 1991 - 1999 (E36)
    Last Post: 11-19-2010, 02:32 PM
  2. Climate Control Panel: IHKA Panel
    By fun2drive in forum 1991 - 1999 (E36)
    Last Post: 01-21-2010, 11:06 AM
  3. @ProStreetDriver, IHKA panel disassembling pics
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 07-21-2009, 11:24 PM
  4. wtb-e36 cp bad interior panel
    By jokermoe in forum BMW Parts Wanted
    Last Post: 03-15-2009, 05:43 PM
  5. Bad Diagnostic Panel???
    By rancho5 in forum 1983 - 1991 (E30)
    Last Post: 09-27-2005, 02:28 PM
