Hello - been trying to figure out a dead speedo issue. Would appreciate any help.
only my speedo doesn’t work, it’s complete dead (not intermittent), everything else is functional. Would this suggest a bad cluster board? Or capacitors?
it’s a 1988 so the stomp test doesn’t work
the obc function reads speed accurately which leads me to believe the speed sensor is fine
1988 BMW 735i
go to my website below, click in index fixes>>>instruments>>>>>Replace blown resistor in speedometer: -- symptoms, write up and photos
01/1988 E32 735i, cluster with grey backplate.
Symptoms:
Speedometer not working at all on 01/88 model 735i. Swapped a different cluster in from another 88 and the speedo works fine (but the gas gauge is intermittent in the other cluster).All other instruments work fine in cluster.
Diagnosis:
Blown resistor on speedometer gauge.
Thanks again! Seems straightforward enough
1988 BMW 735i
