Ok so I got most of my gremlins gone. Now when I start the car cold it will start on 12 then after a minute or so. Right when you can start actually seeing exhaust gas come out it will drop down to half bank . Driver side turning off. No eml light. The light does work and goes on then off on start up like it should. If I get in and rev the engine it will immediately go back to 12. I have scan before and code 16 has been the only code to show. It drives on 12. Literally the only time it drops down is on cold start up. Not a huge deal but it is driving me nuts trying to figure this ghost out. Any suggestions. I have replaced just about everything involved with the ignition system and had the throttle bodies rebuilt by dragon.
Thanks for any advice
Test both your Cam Position Sensors and your Crankshaft position sensors with an Ohmmeter. Test from the inside tab to the outside. One way will give you a reading and the other infinity. report back with readings.
Cam Position Sensors AKA Doughnut sensors are likely the problem.
Test # 6 and # 12 Sparkplug wire for continuity. 6K Ohms
Rjjable. Thank you for the advice. I already replaced the crank sensors
He suggested you test the cam sensors and plug wires 6 and 12. Have you done that?
checked both fuel pumps and fuel pumps pressure?
