Results 1 to 4 of 4
Thread: Will a 1995 OBDI Throttle body work on my 1999 M3?
    Oct 2014
    Ohio/Texas
    2 1999 M3's
    I found a good deal on a dinan throttle body from a 1995 325 and was wondering if id have any problems with it on my 1999 M3? I already have a Dinan chip
    Aug 2011
    WA
    '97 BMW M3/2/5
    Their website lists OBDI throttle bodies as not being compatible with OBDII cars, and vice versa.
    I'm not sure if the parts are completely different, but I know that when I switched to an M50 manifold I had to run a thicker gasket between the M50 manifold and my OBDII Dinan BBTB to get them to mate up. I'm not sure if that is the only difference, or if they have other differences as well.
    Best to shoot Dinan a call to verify about the throttle body.
    And by chip do you mean a Dinan flash? S52's/OBDII cars require ECU flashing, is that what you meant? A chip from a 1995 ECU is not compatible with '96-99 ECUs.
    Feel free to ask about my car:
    TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
    M50 Manifold | ASC Delete | Dinan BBTB | Fan Delete | Power Pulleys | Dinan CAI |
    S54 Oil Cooler
    Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | AKG Chassis Mount Shifter
    SS Long Tubes | SS Race Exhaust |
    LTW Replica Wing | MM Underpanel | CF Sunroof Delete
    OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation | Turtle Labs Door Panels
    And Really Old Paint
    Check out my YouTube channel for more DIY's and videos about my E36 M3
    Oct 2014
    Ohio/Texas
    2 1999 M3's
    Correct my ecu has been flashed by dinan
    Feb 2009
    Arizona
    1998 e36
    Bigger throttle body does nothing except making throttle more sensitive. Don't bother
  1. E36 OBDI throttle body
    By dmb882 in forum Engines, Performance Parts & Software
    Last Post: 01-28-2011, 02:37 PM
  2. E36 OBDI throttle body. Pic inside. $15!!!
    By M3Rob95 in forum Engines, Performance Parts & Software
    Last Post: 10-16-2010, 10:02 PM
  3. Replies: 0
    Last Post: 08-13-2010, 11:32 PM
  4. FS: E36 OBDI Throttle bodies (3) available - $20 + shipping
    By E36M3E in forum Engines, Performance Parts & Software
    Last Post: 07-08-2007, 12:55 AM
  5. Mounting OBDI Throttle body on OBDII
    By bigmansM in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2004, 12:15 AM
