RM European Auto Parts
Results 1 to 11 of 11
Thread: E46 M3 randomly shuts off while driving?
    Jan 2022
    Colorado
    E46 M3
    E46 M3 randomly decided to shut off on the highway. Three times today out of the blue. It shuts off and then turns immediately back on like it cycled it's power. The sport mode turns off and no lights come on for CEL. really weird encounter although it's been somewhat cold in Colorado today was around 50f.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I'd start by replacing the crankshaft position sensor.
    Chris Powell
    BMWCCA 274412
    Dec 2013
    Chicagoland area
    EXOTICS
    According to my own similar experience, I would check for loose battery connections.
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    Yup. Loose battery connections sounds good to me.
    but. I’ll always throw a bet on the crystal ball. Hard to argue against that!!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing a problem is to scan the engine computer (DME) for codes.
    Jun 2002
    E39M5, E500 4WD
    I have known idiots who claimed to have changed the battery while the car was running. Loose battery connection will prevent the car from starting, and/or give a huge voltage spike to all the computers when the cable comes loose, but it won't, to the best of my knowledge, cause the engine to shut off, if the alternator works, unless the DME gets fried from the voltage spike. That said, I strongly advise against anyone trying, and I certainly think it's a great idea to check all primary ground and power connections.
    Besides the crankshaft position sensor, another likely culprit for this scenario is the failure-prone ignition switch. Neither part is terribly expensive, and it's common that when either fails, it doesn't leave a code as evidence. These two would be my prime suspects.
    Chris Powell
    BMWCCA 274412
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Chris, a loose battery cable will cause the engine to shut off. It happened to me. Luckily it was on a surface street and not on the highway. And luckily I was on the side of the street that was downhill so I could coast into an open parking spot!
    Jun 2002
    E39M5, E500 4WD
    Thanks, Mark, I will certainly take your word for that.
    Chris Powell
    BMWCCA 274412
    Jan 2022
    NJ
    2003 3301 sedan
    Ignition switch
    Jun 2002
    E39M5, E500 4WD
    Interestingly, Mark, I had a customer in the shop today, with a towed-in E36. His ignition lock/switch failed when the car was running, and he couldn't shut the car off. So he disconnected the battery hot cable....and the car kept running. He finally got it to shut off by unbolting the main hot feed to the fuse box underhood.
    It doesn't seem like the original poster is ever going to come back to tell us the results anyway.....
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by bmwdirtracer View Post
    This is how my old E36's radio was fried.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. e39 M5 Randomly shut off while driving
    By EsE39 in forum 2000 - 2003 M5 and Z8 (E39, E52)
    Last Post: 06-16-2020, 08:50 PM
  2. E46 FS: E46 M3 non-ZCP PFC Direct Drive Rotors
    By stmount in forum Race Cars & Track Parts
    Last Post: 05-13-2016, 09:15 AM
  3. E46 (2009) shut down while driving
    By Blackminister in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-26-2012, 09:37 PM
  4. 2002 330i randomly shut off while driving.. (fuel pump?)
    By betad0g in forum 1999 - 2006 (E46)
    Last Post: 11-11-2009, 10:57 AM
  5. E46 325ci auto shutting off while in drive
    By Andy in forum 1999 - 2006 (E46)
    Last Post: 06-11-2005, 09:24 PM
