Results 1 to 6 of 6
Thread: e46 to e36 swap
    Jan 2022
    long creek, sc 29658
    1997 bmw E36 conv
    e46 to e36 swap
    Hi All! New E36 owner here. Just picked up a '97 E36 with a blown head gasket. Looking to replace engine and found a good deal on a engine and tranny out of a e46. How much of a hassle am I looking at on the conversion? Owner of E46 will supply DME, Harness, keys and anything else I want off the car. He also says it's a m52b28 engine but the e46 had the m52tub28 engine don't they?
    Thanks for any advice!!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Swapping dual vanos into single vanos is not usually easy. If you want easy, buy a single vanos motor.
    E46 had M52TU - it is a completely different DME setup. You will need to build or buy an adapter harness. M52TU used a cable to operate the electronic potentiometer on the throttle body, so you shouldn't need to retrofit a DBW pedal but electronically it will still require a fair amount of work to retrofit
    PRICE CUT on ALL FABRICS
    Jan 2022
    1997 bmw E36 conv
    Thanks! Yeah from what I've read and your suggestions I think I'll be better off taking some more time to just find a decent m52b28. Thanks!
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by wtd73 View Post
    Or change the headgasket on your existing engine.
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    Or do a LS swap!
    Diving in at the shallow end!
  1. e46 m3 diff swap into e36 m3?
    By tynashracing in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-12-2014, 09:29 AM
  2. can a e36 or e46 m3 motor swap be done to a 02 330xi?
    By 02330xi in forum Engine Conversions
    Last Post: 01-10-2008, 04:14 PM
  3. E46 M3 brakes swap to E36 M3?
    By hotshu in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-23-2006, 08:00 PM
  4. e36 5speed to e46 6speed tranny swap
    By Custom3 in forum 1991 - 1999 (E36)
    Last Post: 08-12-2005, 05:00 PM
  5. E46 M3 motor swap to E36 or E30 possible?
    By m3bmw in forum 1992 - 1999 M3 (E36)
    Last Post: 07-10-2003, 11:15 PM
