Results 1 to 11 of 11
Thread: 95 M3 susp
    Aug 2018
    Ne
    M3,69 Swinger
    95 M3 susp
    A few months ago i bought a 95 M3 5spd.Over the winter i’d like to replace all the suspension bushings.I thought i’d do oem or oem + replacments,Question is does anyone sell a complete kit or do i have to buy them piece by piece. Thx
    San Jose, CA
    00 750IL, 01 740IL
    Quote Originally Posted by 69dart View Post
    FCPeuro
    Sent from my Pixel 4a (5G) using Tapatalk
    Oct 2003
    Seattle
    99 M3
    95 M3 susp
    I believe ECS Tuning and FCP European both sell various levels of OE/OEM and aftermarket component ‘kits’.
    Turner, Pelican and ECS are under the same Investment Group ‘umbrella’. ECS absorbed BavAuto inventory.
    Validate OE part numbers using the last seven characters of the VIN in www.realoem.com
    Jun 2010
    south central PA
    1997 m3 4dr - e28.....
    there wasnt a kit when i did this and there are a few things a kit might not have
    all rubber is not created equal. make sure you buy lemforder or OEM for the hard to get to bushings at the least. subframe bushings in a e36 sucks. make sure you replace the front differential bolt while your in there. dont bother trying to replace the lower rear control arm bushings on the diff side either get new oem arms with the reinforcements welded on or adjustable arms. the rear upper control arm is a delicate part I wasn't going to put it in a press so i changed the bushing with allthread and sockets, i was sold on the upgraded group N bushings for a stupid price but i dont belive it any better then oem, the trailing arms themselves will be the first bushing that will need replacing after a few years. so make sure you put the limiters in there to keep the movement and wear down.
    you can and should use the ball joint in both rear outer trailing arm locations if you have bushings in there. i think 1995's didnt get the spherical bearing the 96+'s got.
    there is a size upgrade you can do to the front diff bolt i didnt do it and ive never boken mine, however i put in a bmw stamped bushing a bolt when i did this. and torques it to spec.
    make sure you get the correct front strut mounts, they are 1995 M3 specific, or upgrade to camber plates. i have ground control street plates on my 97 sedan an love them.
    i luckly havent had this issue with bmw's yet but ive gotten boxes and boxes of trash rubber for my etype. craps been on a shelf for decades. every peice of rubber i put under the hood is cracking an falling apart
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    Fcp euro has a good kit but like others have said, sometimes they mix in non oem stuff like meyle. Best to just build your own by referring their kit and selecting oem stuff. That said, stick with fcp euro for the lifetime replacement warranty if you keep your car long term. It cost me $2k to replace every piece of rubber underneath the car.
    Aug 2018
    Ne
    M3,69 Swinger
    Thx all,huge help
    Oct 2003
    Seattle
    99 M3
    95 M3 susp
    Quote Originally Posted by scoobiedoo2029 View Post
    Ya, the 1995M3 got a rubber isolated lower rose joint while the upper joint is a full metallic joint.
    1995M3
    33306852895 Ball Joint - Upper
    33326771828 Rubber Mounting - Lower
    1996+M3
    33306852895 Ball Joint - UPR/LWR
    31332228345 Guide Support - 1995M3 (2)
    31332227897 Guide Support - Left 1996+M3
    31332227898 Guide Support - Right 1996+M3
    Unfortunately, there is no OEM/aftermarket option for the 1995M3 Guide Support.
    Jun 2010
    south central PA
    Quote Originally Posted by bluptgm3 View Post
    Unfortunately, there is no aftermarket option for the 1995M3 Guide Support.
    vorshlag or ground control race plates, and possibaly the tc kline plates, would have to correct range of adjustment to hit stock 1995 caster, the 1996+ caster setup (ground control street plates) might push the wheel to far forward and may contact fender liners with stock 1995 front suspension setup. there is without a doubt many 1995 m3's with camber plates, but i dont see a marketed street option. i thought ground control sold one, might be discontinued or im mistaken
    Marietta, GA
    95 M3, 87 535is
    These plates are built for 95 M3 geometry.
    https://groundcontrolstore.com/produ...es-and-z3-pair
    Oct 2003
    New Jersey
    E36 M3 / 991.2 911
    OP: I just went through this same process. Many 95 parts are different from 96+ so keep that in mind.
    Order Meyle HD or Lemforder parts only. The front control arm ball joints can be pressed out and replaced if you have the patience to do so, otherwise, e30 arms also work for the 95's (you can do a search on this). If you care about ride quality, then stick with the OE strut mounts which are specific for the 95's. I ended up ordering 3 so I have an extra, let me know if you are interested in it.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by jayjaya29 View Post
    Don’t think these fit OE/OEM springs
  1. metallic "clack" from front susp over bumps. 99k-mi '95 M3 w/bilsteins
    By TheNorthWaves in forum 1992 - 1999 M3 (E36)
    Last Post: 10-29-2008, 10:31 AM
  2. WTB some stuff for 95 m3(bushings, susp, harnesses)
    By MSFIT in forum BMW Parts Wanted
    Last Post: 08-16-2006, 08:14 PM
  3. Will a 95 M3 Susp fit in place of my 98 sport suspension??
    By Glenn 328is in forum 1991 - 1999 (E36)
    Last Post: 10-04-2005, 01:08 PM
  4. will strut bar from 95 M3 fit on a 93' 325i 4dr?
    By dees in forum 1992 - 1999 M3 (E36)
    Last Post: 03-01-2001, 02:55 PM
  5. Parts from my 95 M3 for sale..
    By TKM3 in forum BMW Parts For Sale
    Last Post: 02-28-2001, 07:49 PM
