Results 1 to 2 of 2
Thread: O2 Sensor Spoofing...
    Oct 2020
    Oakland County Michigan
    2005 x3 3.0i (e83)
    So I'm getting a "Stuck Lean" issue with a brand new lambda sensor, after installing a fun manifold (you know) and realizing that the post cats would not fit between the extended bung and side of the exhaust passage... I chose to put the included filler bolts in and live with the CEL.
    Of course in my infinite genius there was nothing plugged in to the bank 2 1 and 2 plugs, and having heard from someone that this could cause electrical gremlins, (beats me), I decided to wire up an o2 sim, instead of paying a million bajillion dollars for some, since they just seem to consist of a resistor and a capacitor.
    My question is, I read somewhere for bosch that you use a 1 mohm resistor, a 50ohm/12w capacitor(for heater), and a 1 uF capacitor.
    Does anyone have any experience with this to tell me if these numbers are right and/or give me any advice on what to do in this particular situation?
    (It should show but just in case its the e83 m54 3 liter)
    Nov 2012
    Westfield IN/Hinsdale IL
    2006 750Li, 2005 V70R
    Not sure about that but some cars a spacer will work. Called a spark plug non fouler, super cheap to buy and try. Might be worth a shot.
  1. Lazy O2 Sensor or Gremlins?
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2001, 06:00 PM
  2. any tips on installing O2 sensor in 94 325?
    By madsedan in forum 1991 - 1999 (E36)
    Last Post: 03-11-2001, 10:17 PM
  3. How do I replace the O2 Sensor?
    By Zippy M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2001, 09:58 PM
  4. O2 sensors for 325i. How many are there?
    By ///Arman in forum 1991 - 1999 (E36)
    Last Post: 03-07-2001, 05:56 PM
  5. O2 Sensor Questions
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 02:08 AM
