Want to buy: gearbox output flange for a ZF 5 speed gearbox. I believe same on all ZF310 and ZF320 gearboxes. This is the part that connects the Giubo with the gearbox![]()
Do you have a part # for the output shaft?
The part number on the flange is 1053 304 269 but I don't know if all flanges had this number stamped into it. I made a quick diagram to help.
The distance between the 3 flange holes (value "H" center to center) is about 83mm.
The Giubo "size" i.e. "PCD" is 96mm.
Anyone?
Plenty have broken ZF320 so they should’ve floating around if you can find the right person. Like a turbo E36 owner who has broken a few. I probably have one somewhere but don’t have time to search.
Bumping - still looking for this flange.
