I had this kit installed on my s50 e30 for about 5 years, and it was always reliable, until a bad tank of gas took out 5 piston ring lands.
I'll start with the bad: The RMS thermoplastic intake is ugly and was modified by the previous owner, I never got around to getting a new one because it still works.
I had to grind a bolt lug off the blower head unit to make it fit in my E30, This doesn't affect it's performance in anyway, but I did it in my driveway with an angle grinder so it's not the prettiest.
The powdercoat on the RMS heat exchanger is cracking in a few places.
I would replace the belt tensioner, the oil as I have no idea how many miles are on it, although it was still functioning perfectly.
The headunit is marked as a v1 on the volute, but the plate on the gearbox is stamped v2, it's definitely a v2 gearset as it's nowhere near as noisy as a v1.
Hardware is all new from MSportParts.com.
Upper and lower legs were repowdercoated recently.
Bulldogge 6" 6 rib crank pulley and 3.13 blower pulley (I think this is a 14psi combo, it might be 12 though) with correct length 6 rib belt
42 lb/hr lucas or bosch fuel injectors, depending on which tuner you plan on using
EvolutionMotorsports aluminum bypass valve.
Newer bosch waterpump for the heat exchanger
$2250 obo
I'll get everything out of storage and get pictures over the next couple days, you can text me at 7oh7 five99-two8four3 as I don't get on here very often anymore, located in Spokane Wa
Awaiting pictures...
sent you a text - hoping this is still available. thanks!
'72 2002 pickup | '88 M5 | '89 330is | '89 M3 | '01 Z3M | '11 328xi-t
Sold
