Results 1 to 6 of 6
Thread: "Door open" warning
    Wisconsin
    '95 525it
    "Door open" warning
    I had a Ford Ranger with a similar problem: I'd "load" the car to the left or right (right in the Ranger's case) and I'd get a warning that a door is ajar. All doors are secure, so it's likely a microswitch failing somewhere.
    The question is, where? The Ranger's problem went away temporarily when it slathered the driver's door latch in silicone juice. But the wagon has five doors. I guess I'll have to lube them all up, but it would help if I could narrow the trigger point down.
    The Ranger's issue was on the driver's door, since it got the most use. I'm thinking of going after that door first and most aggressively. I've also noticed that central locking is balky on the driver's door -- if I lock with the key at the shotgun door, everything locks but the driver's door. Thoughts?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    look inside the door latch striker, there is the microswitch
    Wisconsin
    '95 525it
    Quote Originally Posted by shogun View Post
    Thanks, Erich, I'll see if I can spot it.
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    I have strikers if you need one. Just let me know.
    Andy
    May 2014
    South Florida
    1991 318is, 1994 525iT
    The plastic contact bumper on the striker switches wear down with time. A dab of JB weld on each that is worn is the easiest way to fix it.
    '91 318is, M20B25, T3/T04E 60 trim (18psi), megasquirt, coilovers, Z3 rack, cold AC. Project thread
    '94 525i touring slicktop, 3L stroker M50 w/BW S362SX-E
    Wisconsin
    '95 525it
    Yes, I think it's a matter of wear. All the strikers look pretty good except for the driver's. I've adjusted it a bit to see if that helps.
  1. Doors open cluster warning not working
    By BerDz3nA in forum 1996 - 2003 (E39)
    Last Post: 03-17-2019, 12:12 AM
  2. 2004 745i "Door Open" Warning
    By Easyrider1 in forum 2002 - 2008 (E65, E66)
    Last Post: 06-10-2007, 02:01 PM
  3. "Door Open" warning message
    By Doog in forum 1995 - 2001 (E38)
    Last Post: 05-01-2007, 01:18 AM
  4. HELP, 1994 740i Door Open Warning
    By glofton in forum 1988 - 1994 (E32)
    Last Post: 03-10-2007, 03:47 PM
  5. sticky door lock/door open warning?
    By DRDCQX in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 12-15-2006, 01:25 PM
