Page 1 of 4 1234 LastLast
Results 1 to 25 of 99
Thread: 1999 E39 no speedo, abs and triangle light
    Nov 2021
    NJ
    1999 528i
    I'm about to acquire a 1999 e39 with the sports package. During the test drive I noted no speedometer (tach was working), abs light and circled triangle. My first thought was bad abs sensor.
    Looking for a good way to diagnose. I think I watched a few videos a while back on how you can test a abs sensor with a multimeter.
    Is there a specific tire that provides info for speedo? My thoughts are to start in the rear. Considering jacking and removing tires all takes time and the sensors are not cheap I'd like to try and zero in on this problem as best as I can. I was also advised that if it's not the sensors it could be the abs module that I can get rebuilt. Either way it's one of the first things I have to tackle when I get possession of this car.
    Thanks,
    Roveer
    NW suburban Chicago
    hiss by my window
    Common issue with that car's Bosch 5.7 abs. It deserves proper diagnosis but the writing on the wall says that the module is likely dead. Many offer re-man service with varying results.
    I used Module Master a decade ago and my module is still working just fine.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Get out your test tool
    suggestion
    FOXWELL NT510 Elite Full Systems Scanner
    https://www.amazon.com/FOXWELL-Autom...38391267&psc=1
    You will need the ROUND pin connector for your EARLY OBDll system as the connector is under the hood on the RIGHT shock tower. BMW fought the OBDll Federal mandate for years so the early cars have two completely separate connectors one under the dash OBDll Federal P codes only and the round pin connector under the hood for the BMW specific codes and activation access.
    The questions you need to diagnose/test and confirm are the following:
    Does the computer see the signals from all the speed sensors? Y/N
    If no, check the wiring to each one and especially the connection to the body harness. Remove each sensor (just a 4mm sq drive) twist & pull to remove. Clean the sensor and clean out the hole to the hubs and spray down with brake clean the hub area to remove the 20+ years of road crud. These things put out a square wave that can be tested on an oscilloscope. There are other static tests but they do NOT give you any confidence of good/bad as weakness and intermittent are usually the culprits. Most DIY when they discover the wiring jacketing flaking off, just replace all four. They plug in at the back of each hub area and the quick connect in hidden in the little rectangle box in the inner fender wheelwell. DONT BREAK the box or the connectors!!!
    Vendor Sources: Rockauto.com
    Brands: VDO, Hella, NTK (NGK), Bremi
    Are there any codes present in the systems?
    Are you able to clear and retest the system?
    Does the ABS module cycle when commanded?
    As Rossi mentioned, the ABS block and module are a HIGH failure item in e39's due to the location just above the exhaust systems and the technology they were made from in the late 90's. There are a few "rebuilders" who can bench test and repair the circuit boards that will get your module back into the functional world.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Who ever told you it wasn’t the sensors, strike him off the list of who to get info from.
    Check the left rear wheel speed sensor.
    Nov 2021
    NJ
    1999 528i
    Quote Originally Posted by BimmrMeUpSnotty View Post
    A good place to start. Exactly what I was looking for. Probably not a bad idea for me to get a look behind each tire so I know how things will be going forward. I owned the car from 1998 to 2011 then sold it and have now bought it back. Funny how these things work.
    Roveer
    What i can report from the day I test drove the car. It didn't have a check engine light. I scanned it with my generic OBDII scanner and no codes found. I'm probably going to "get" the car this weekend and then I can start looking at all these systems.
    Is there a defacto BMW obd dongle/software? I saw BMW Scanner 1.4 and K+DCAN. I have one for my ford and I use forscan. Guessing there is a similar for BMW?
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Yep,
    it is the speed sensor at the left rear wheel. Clean it, test it or replace it with an oem speed sensor.
    And no it is NOT the ABS,,
    Nov 2018
    La Habra, CA
    2002 525i
    Quote Originally Posted by roveer View Post
    Roveer
    I had to buy a K+DCAN cable for INPA and a different cable for BMW Scanner 1.4. I don't think the cables are interchangeable. Those are the two de facto programs for these cars.
    Current stable:
    2002 525i (Daily Driver)
    1994 SN95 Mustang 'Vert (The Bumblebee)
    2001 325i Convertible (Beach cruiser project)
    Nov 2021
    NJ
    1999 528i
    Quote Originally Posted by Chedley View Post
    Yep,
    A little confused. You saying speed sensor is NOT abs sensor? Is this sensor (speed) not on the rear wheel hub? Is it on the driveshaft or some other place? I always refer to the sensors mounted on the wheel hubs as ABS Sensors. I'm missing something here.
    Quote Originally Posted by E39 Newbie View Post
    Did see a video where they showed both types of dongles and yes, they did mention that there was different software for each. Is it normal to own both or does one do most/all of the necessary functions. No sense in buying things I don't need.
    San Jose, CA
    1997 BMW 540i 6 speed
    AFAIK, the '97-'98 ABS module is under the passenger footwell; at least, it is on my car, so it is not subject to exhaust heat.
    Nov 2018
    La Habra, CA
    2002 525i
    I have both. They each have their place and there is quite a bit of overlap. I find PASoft more user friendly.
    Except for the price of the cables, both are free downloads. Google Mike's BMW Tools for INPA and ancillary programs. I think I went to https://bmwpasoft.com/products/bmw-pasoft-software and bought the dongle, although they're available on Amazon and elsewhere. The software was included. I think both titles are also available on MEGA.
    Current stable:
    Oct 2017
    Yes, the speed sensor is on the left side (driver side) rear wheel hub. Some call it ABS sensor. But do not confuse it with the ABS module. I am saying that your problem is the speed sensor, and not the ABS module...!!
    I recommend the K+DCAN cable for INPA, free downloadable software. Google "Mike's BMW Tools for INPA".
    Nov 2021
    NJ
    1999 528i
    That's exactly as I was expecting. I'll go for the sensor first and then the module. Hopefully it will be the sensor and I'll get off with a 50 dollar fix.
    Do either of these software/dongle combos program door unlock buttons? I remember when I sold the car the key would not unlock the car. Something about the battery (either car of key) being dead and then losing it's programming. I noticed when i test drove the car that the key would not unlock the car. Might just be a battery, but if the programming issue arises again I don't want to have to go to the dealer to reprogram.
    Roveer
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Roveer
    At 23+ years old, your E39 most likely needs to have all 4 wheel speed sensors replaced due to old age making the plastic housings and wire coatings brittle and probably broken, causing either shorts or breaks in the circuits. I had this same issue with the speedo - the LR sensor was broken, and I replace all 4 at the same time as repair/preventive measure. I don't believe the '98 year ABS modules are problematic. Most ABS issues are posted for '99+ years.
    The key issue may just be that the FOB battery died and the key needs to be re-synced, which you can do yourself. Search the forum here for the procedure - QSilver has posted the key sync procedure many times here. So, no need to go to the dealer for re-sync.
    It's nice that you got your old E39 back. I've had mine for over 20 years, have maintained and repaired only with DIY, have never gone to the dealer, and can't bring myself to part with it because it still runs like new and is a joy to drive. Good luck with your re-aquired toy!
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Ed CT View Post
    Correct Thread title says '99, sig states '98 so who knows which one but pre '99 aren't problematic.
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Ha! Didn't even notice that. I was only looking at the sig year. OP should to clear up this discrep! Esp. since '99 is first TU year.
    EDIT: A second look at OP's other "Should I buy back my "98" thread is where the '98 originated. OP - are you buying another E39?? LOL
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Feb 2014
    Alexandria, VA
    Whats the big deal? I have three, if a good deal on another one manifested itself, I’d jump on it.
    Nov 2021
    NJ
    1999 528i
    Actually when I made the original post. I couldn't remember what year the car was. After looking at VIN I determined it was a 99
    As a test can I swap rear ABS sensors to see if it resurrects speedo? Hate to start buying 80 dollar parts that I can't return.
    NW suburban Chicago
    hiss by my window
    I've had mixed results with the cheapies. These; https://www.ebay.com/itm/263904867997 being the worst*, two of two were DOA. I've bought good ones for as little as $10. These ain't rocket science.
    *Seller has since "revised" his listing which conveniently eliminated my feedback.
    Nov 2021
    NJ
    1999 528i
    80 bucks is when I go to auto parts. Seeing that weekend is over I will just order on rockauto. But I'd still like to know if swapping rears might ressurrect speedo? Want to determine if it's sensor or module. I pulled left rear, cleaned and tried, but no joy. Next is to pull it completly and try and test with multi-meter.
    NW suburban Chicago
    hiss by my window
    You can check from the module connector. The RR is pins 30 & 31, LR is 13 & 29 an ohm meter should indicate low impedance when connected one way and an open circuit when the leads reversed.
    Given that the wiring(connectors) are sometimes the problem this method includes that variable.
    According to my notes #13 is blue/wht, 29 is wht, 30 is blue/grn and 31 is green
    Hope this helps.
    Nov 2021
    NJ
    1999 528i
    I pulled both rear ABS sensors and tried to test them. The pins are very deep in the connectors but I think I made connections. Neither one gave am ohms reading. I was able to get a single new sensor and put it on the back left (driver side). Still no speedo. I'm going to test the connections from the connectors to the module next.
    Question: Does it need both rears in order for the speedo to work or would it / should it work with just the left rear? This is a 99 so does that mean that it's more likely to be the module? 185 bucks ebay rebuilt.
    Roveer
    Feb 2014
    Alexandria, VA
    The left rear speed sensor is the one that gives the speedo its sense.
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Yes, the more E39's on the road, the better. These cars are too good to go to the scrapyard.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Roveer
    The'99s and up have the more suspect ABS modules; however, the wheel sensors at this age are most likely in need of replacement. Swapping them side-to-side is likely to damage them during handling. If you got a single new sensor and it doesn't work, you may want to check that it is actually good, as Ross says, some fail right out of the box.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    a reader like the foxwell 510 will tell you which corner has the error. Disturbing sensors that have not moved in 20 years is a losing game. you will spending more money on new sensors than the tool cost.
  1. 1999 E39 Internittent fault: Speedo not working & ABS+ASC warning lights on.
    By Davepeers in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-02-2015, 10:03 AM
  2. speedo/abs/dsc lights
    By dok528i in forum 1996 - 2003 (E39)
    Last Post: 01-20-2008, 05:59 PM
  3. Speedo stopped working ABS, Traction Control lights on, help
    By Vonbimmer in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 02-21-2007, 08:22 PM
  4. 1999 528i ASC and ABS light on Speedo quit too...
    By dfw2bmw in forum 1996 - 2003 (E39)
    Last Post: 12-04-2006, 03:58 PM
  5. '97 E39 ABS-ASC-Airbag lights-not shifting.
    By Lustig in forum 1996 - 2003 (E39)
    Last Post: 11-01-2006, 10:15 AM
