Results 1 to 14 of 14
Thread: Rear Brake Rotor Stuck
    Los Alamos, New Mexico
    1988 735i
    While waiting for the machine shop to finish with my block and head, I decided to do the shocks and springs on my 735i. I then decided that I might as well do the trailing arm bushings as well. After all, they're right next to it, right?
    Somehow, the job has been going smoothly, except that my right rear brake rotor is stuck. I imagine the left is also stuck. This means two things: This has turned into a brake job as well, and something is going on with the parking brake. I'm guessing that the parking brake has worn into a groove and now the rotor is stuck. I have tried to use a screw driver to release the sprocket thing, but I have failed miserably at it. I have said several horrible things to my car, and I'm getting ready to take my 30-30 to it.
    Does anybody know how I can get the rotor off?
    1988 735i
    Nevermind. In my rage, I decided to burn the rotor. Metal is not flammable. Upon realizing this, I went after it with a rubber mallet, the closest weapon available. Rotor broke loose. Turns out burning things and hitting them are the answer to all my problems.
    Richmond, Virginia
    '88 735i, '06 RSX
    Quote Originally Posted by nm735 View Post
    Iíve used a big block of wood to smack the rotor from behind, as well as a rubber mallet with success. Glad you got it off! Itís always frustrating when youíre working and get stuck trying to take something off
    1988 735i
    New problem: I have no idea how to disconnect the parking brake cable. It is just stuck in the actuator, and then I don't know how to disconnect the sheath from the hub. Anybody else do this before?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    1988 735i
    I did check the Bentley. It just says "disconnect the cable." I was able to discern the little pin holding the cable in after about an hour of looking at the thing. Tapped it out after about 15 minutes of swearing.
    All of this looks helpful. I have sprayed the cable sheath with PB blaster, and I will do my best to yank it tomorrow. It seems to me as though there is no trick to it. Just oink on it until it comes out. Which is gonna feel great.
    Jan 2005
    Japan
    2nd one will go faster, even the workshop manual does not help, one sentence only: unscrew parking brake cable on trailing arm and pull out
    Shogun tricks and tips for the E32 series http://twrite.org/shogunnew/topmenu.html
    1988 735i
    Fire is the solution to everything. I have gotten the damned trailing arm off the car. It took all day. Everything you sent me was technically completely accurate, but was not enough to prepare me for what I had to do.
    I unhooked the parking brake cable from the handle, and pulled it out. I have no idea how I'm going to undo that, as it won't pull out, but that's future-me's problem. I used a punch to tap out the housing. The punch got stuck next to the cable. I heated up the end of the housing with a torch and it released. The last thing holding in the trailing arm was the ABS sensor. The Bentley manual said "remove ABS Sensor." It took hours. Alternating between a rubber mallet, a slide hammer, a torch, and PB blaster, I was able to eventually free the ABS sensor. The trailing arm is now free. Now all I have to do is press out the old bushings and press in the new bushings. Then I reassemble. Then I do it again on the other side. Then, I have to do the front springs. I'm going to die.
    I hate this car. But it can't win.
    Jan 2005
    Japan
    soon you will have done the repair. Here one more link https://www.newtis.info/tisv2/a/en/ maybe there is something inside more in detail, you have to register and log in.
    1988 735i
    Update:
    The other side is going faster. Some of it is that the driver's side is cleaner. Most of it is that I now know how to do these things better. I have dislodged the cable from the driver's trailing arm, and am working on freeing the ABS sensor prior to removing the drive axle and strut. My next question, and I regret asking this, is how much more work is it to remove the rear differential from here? Should I even bother doing it?
    Jan 2005
    Japan
    I only removed some final drives from parts cars but never installed one, I used the Bentley which you also have. Any special reason you want to remove it? Seal replacement is possible w/o removing the diff, see here under driveline http://bmwe32.masscom.net/
    http://www.bmwe34.net/E34main/Mainte...tial_seals.htm
    1988 735i
    The single biggest reason is I don't think it's acting as a limited slip differential anymore, but my Father has given contradictory statements about whether he has seen both wheels turning in the snow. When I changed the diff fluid, it was disgusting and I am worried that the diff has been damaged.
    Also, I figured it might make sense to replace the mount and any bushings under there. It doesn't take much to get back under the car. But I also am having a hell of a time with simple things like the brake sensor, so I'm wondering how difficult it actually is compared to the manual.
    Jan 2005
    Japan
    this will help http://www.bmwe34.net/E34main/Mainte...fferential.htm
    If you would like to know what kind of diff is installed in your car, refer to the data tag located on the rear driver's side of the diff. For example "S3.15" means a LSD 3.15 diff while a "2.93" means an open end 2.93 diff.
    1988 735i
    You're a godsend. Looking at that article, I have decided it is not worth the trouble to pull it. It still works fine for my purposes, and the engine isn't putting enough power down to make an open diff a nightmare. I'll have it yanked when I have the transmission yanked.
    That said, I believe the diff to be original to the car, which means it is the 25% slip diff listed on the build sheet. I cannot verify this, however. Years of neglect have left the tag illegible. It's possible it has been swapped out. The transmission is not original to the car, and neither was the ECU I found when I decided to replace the ECU. By my count, there are at least 7 other cars with parts in mine. So it wouldn't surprise me so much if the diff were a replacement. It would surprise me that somebody bothered to do it, but then again this thing was valuable once.
  1. How to remove rear brake rotors on E36?
    By Poke2120 in forum 1991 - 1999 (E36)
    Last Post: 07-18-2004, 04:56 PM
  2. FS: 323 rear brake rotors
    By pezking4 in forum BMW Parts For Sale
    Last Post: 04-21-2004, 07:22 PM
  3. Removing rear brake rotors
    By ss109 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-16-2004, 04:27 PM
  4. Best price on rear brake rotors?
    By document in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2003, 03:43 PM
  5. Using SOLID rear Brake rotors?
    By IslandS62 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-09-2003, 08:33 PM
