Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: Replacing Knock Sensors
  1. #26
    Space Coast FL...Beachside
    '95 Dakar M3
    WoW!! Big difference in drivability after knock sensor replacement!!!
    Car no longer pings under load around 3k rpm. CEL gone for a full day now. Feels like car is smoother now that the ECU is freaking out and retarding timing.
    If you're throwing the 1226 code, just get it done!
    Highend Landscape Lighting in Florida.
    Check us out!
    http://www.alulighting.com
  2. #27
    Mar 2003
    San Fernando Valley,CA - (SoCaL)
    Yamaha R6, Avus E36, MBZ C230
    does anyone have a picture of what position the #2 knock sensor is supposed to be in? im not sure if mine is correct.
    -phill F.- 10/95 Avus E36
  3. #28
    San Diego
    95 Cosmos M3
    I hate to bring this thread back from the dead but if my car has a build date of 8/95 is that considered late or early build?? Im curious if i could do the "come from beneath" approach.
  4. #29
    San Diego
    95 Cosmos M3
    bump again...any help??
  5. #30
    Palm Springs
    2015 M5
    idk i have a 04/95 and am currently doing the head gasket...i took the intake manifold off this week and it was a bitch but i got it done with no prior mechanical experience and a mediocre set of tools....so just take off the intake mani and you can fix other common problems at the same time
  6. #31
    Apr 2003
    South Carolina
    2006 Z4 3.0si TiAg
    Quote Originally Posted by parkeryo View Post
    My 95 was a very early build car (8/94). There was no way, I could have done the job from underneath - imo. It is not that hard to do from above, just need patience.
    Jeff
    2006 Z4 3.0 si
    6 spd
    2004 325i auto (DD). GONE.
    2013 Honda Ridgeline
  7. #32
    Feb 2010
    Baltimore MD
    93 BMW 318i
    My check engine light came on and it blinked the code 1286 which essentially is telling me to replace my knock sensors. The problem is I drive a 93 318i how different is the procedure for the replacement from what was stated above?
  8. #33
    NY
    '95 M3 + 86.5T Supra
    1286 is knock control test pulse. Never got that before.
    By the way, you don't need to remove the manifold to do this, and it can be done in less than three hours.
  9. #34
    Feb 2010
    Baltimore MD
    93 BMW 318i
    @shaeff very cool thank you I figured with the much smaller 318i engine I might be able to get around it to access the sensors without having to go to all that trouble hopefully it will work out.
  10. #35
    NY
    Ah crap, I missed that you had a 318i. Reading > Me lately.
    Have you looked under the hood of a m/s50 motor? I replaced the knock sensors on my s50 without removing the manifold in just a few hours. Here's my thread:
    http://forums.bimmerforums.com/forum....php?t=1288770
    Not sure how much easier, or more difficult it is to work on the 318, but if the manifold is around the same angle you should be able to reach what you need.
  11. #36
    San Diego
    "stock" 95 M3, 97 318ti
    Hate to bump a thread (although its an amazing one), but is this the correct part?
    12141738667
    Number 14
    -Brandon
  12. #37
    NY
    Yep, that's it. I believe RMEuropean refers to it as a Ping Sensor. Do both.
  13. #38
    washington dc
    Avus Cosmos Calypso!
    bumping this great thread up...what else to replace besides the vacuum lines and clamps for the fuel regulator while doing the knock sensors? Part numbers please! Thanks!
