Well it's back on the road. Took the subframe out and bent it back with a sledge hammer. My brother came out to help thank God because I had lost all motivation. Now on to an alignment and getting some real tires on.
01' 750il Chromeline
95 M3 LS swapped
07 M5 Manual
06' M5, Spartan wheels and a 507hp V10
00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
00' 323i wagon for daughter
03' 525i wagon for the wife, sold
98' 740i for the daughter, wrecked
92' 525i with over 200k, wrecked
02' R1200 CLC, hit by a bus and broken in half. That one made the news!
It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
I have a question, Ground control finally got back to me and now I know at least what I have. The front springs are 388lbs and the rear are 550lbs. According to the guide the rear are correct and the fronts are light. The LS-tremec combo is likely to be close to the S52 with accessories. I'm inclined to at least get to the 525lb in the guide to get started? The whole ac system is gone including the condenser. The hood being CF is a weight drop as well. When I get the camber plates and get the camber where I want it I will get a weight balanced alignment which may reveal a problem with the spring weight.
95 M3 LS swapped
07 M5 Manual
Wow ... those are ridiculously soft ... If this is a track only car, I'd be looking at 700+ for fronts, and 800+ for rears (assuming non coilover rear)
Not sure I would run rates that stiff on a Koni based single adjustable. I would throw some 450 or 500# front springs on for now until the car is shaken down and you are ready for a serious jump in shock. Something like an MCS with 600/700# split or 700/800# if you like a stiffer chassis feel. I don't mind a softer spring on the e36 chassis, seems to drive more "playful" compared to an e46 or e90 that really needs a stiff setup IMHO.
Thanks for the confirmation. The springs are pretty cheap so I can go up easy. I have been looking at the suspension guide from the beginning but I'm sure as time goes on there are other/better options. I would not call the car soft on the street but I'm sure it could be stiffer.
95 M3 LS swapped
07 M5 Manual
There really is no problem with just running your 150# split for now while shaking the car down. I find keeping the list as short as possible helps to get projects on the road and then tinker with each system one at a time as you are trying to improve the car.
I'd get the dampers rebuilt/revalved while they are off the car. OTS Koni setups don't like a lot of spring in my experiences.
The track will reveal all if I can ever get on it? Been white and cold here for the last few days.
95 M3 LS swapped
07 M5 Manual
Got some Kosei K1's with Hoosier H2o tires.
Way more grip than the garbage that the PO put on it and about 10 pounds lighter per wheel.
https://www.youtube.com/watch?v=-0WMqdUihp0
95 M3 LS swapped
07 M5 Manual
Those H2Os will disintegrate quickly if you run them in the dry. They are intended for wet racing usage.
Good to know. I get back off the ship in March so it should still be wet for most track days. I used to get worried about tires but they go so quick I just run them until they are gone and buy more.
95 M3 LS swapped
07 M5 Manual
I'm back! Got off the ship about ten days ago. My Suburban took a crap so that has been in the shop for about a week. Already had two track days canceled, one at PIR and one at the Ridge. I got camber plates for the E36 and my son painted the front of the car while I was gone. We have an autocross event tomorrow so I have been prepping for that.
So installing the camber plates I have a few questions. I did not get to hung up but just want to make sure I'm not doing anything really stupid. I believe I removed M3 post 95 strut tops? When I was installing the camber plates there was a washer underneath that is tapered to match the strut shaft. It does not sit inside the bump stop plate but that is the way I found it. I can get plenty of camber but it looks like you have to adjust the camber first and then the caster. The M3 plates had a lot of caster and I'm wondering if I should max the caster out?
On the rear I have adjustable tie bars and have at least evened out the camber. I see no other adjustments and was wondering if I need to add eccentric bolts to adjust the toe once I get the camber where I want it. Prepping Matthew's 318Ti today so hopefully he will have a good time tomorrow. Wish me luck! It's not a track but will be the first event for the LS M3
95 M3 LS swapped
07 M5 Manual
Those plates look odd, add a lot of stacked height, and looks like no upper perch adapter.
The factory bump stop piece probably wont support the spring weight.
Check out vorshlag or ground control plates for reference.
Quality BMW service "street, track, race"?
Email: ZakspeedRacer@gmail.com
1999 BMW 318Ti/M Hellrot Msport DD/Fun car
1/2 1987 BMW 325is/M Future Spec e30 (track prep'd)
1994 530It/A Alpinewise III Traded out
1988 BMW 325ix/M Diamond Schwartz Recently sold :/
1986 BMW 325e/m Bronzit Beige Metallic
Get Involved!
www.bluegrassbimmers.org
OKI BMW Facebook group
BMWCCA Member# 436428
My old car. When I built it, 2011 - 2018 I never intended it to be a track car, just a fun street car.
What happened to the beautiful M Contours that were on it?
1988 911 - Carb'd - Twin Plug - 3.6
1999 SL 500
2016 4Runner TEP - Gone
1995 M3 - LS2 - Gone
1998 M3 - Gone
1991 M5 - Gone
1993 RS America - Gone
1995 M3 - Gone
