1 Lot of BMW E36 3 SERIES PARTS
- Purchased for personal vehicle 1998 BMW 328i sedan with auto transmission & M52 2.8l inline 6 cylinder engine. Vehicle was sold.
- Part numbers included in photographs where available.
NEW parts:
- 1 pair KONI rear STR.T perfomance shock absorbers
- 1 set Corteco engine mounts w/hardware
- Phillips & Michiba exterior light bulbs
- 1 set FelPro intake manifold gaskets
- 1 MSportParts trunk latch reinforcement plate
- 1 Autopart International cabin air filter
- 2 sheets Boom Mat sound deadening material 12.5" x 12"
- 2 Chase Bays ground cables
- 1 URO parts vanos oil line
- 1 BMW vanos solenoid piston w/spring
- 1 fuel injector install kit (incomplete)
- 3.3 mm silicone vacuum hose (various lengths)
- 3.5 mm silicone vacuum hose (various lengths)
- 1 BMW front hood cable
- 1 BMW fender to interior hood cable
- 1 set Garagistic aluminum throttle cable bushings
- 1 BMW front bumper mounting hardware kit (incomplete)
- 6 Bremi spark plug boots
- 1 TYC driver front indicator signal lens
- 2 TYC side indicator lenses
- 1 set UUC delrin brake pedal bushings w/hardware
- 1 set Revshift 80a durometer transmission mounts w/hardware
- various fuses, gaskets, hardware, hoses, hose clamps, o-rings - SEE PHOTOS
USED parts:
- 1 AFE Power throttle body spacer w/new hardware & new gasket
- 1 BMW engine ECU/DME MS41.1 (operation not confirmed)
- 1 BMW ASC traction control secondary throttle body w/sensor & bracket
- 2 bags BMW miscellaneous/spare hardware fasteners & clips
- 1 set hood insulation clips (incomplete)
- 1 set BMW valve cover nuts & washers
- 1 set BMW hood latches w/hardware
- 1 set BMW under panel 'pork chop' mounting hardware (incomplete)
