Results 1 to 11 of 11
Thread: Engine Dies in Sport Mode?
    Apr 2002
    Florida
    Coupes...
    So I was out exercising the SG yesterday and I have a tendency to coast to stops in neutral with the clutch out, sometimes the engine stalls out on me while I'm coasting at 50 mph or whatever.
    I put it in gear and let the momentum spin the engine back up, but its probably not good if the engine isn't designed for that kinda think like todays boring cars.
    Think I need to clean something or a hose somewhere? Anyone experienced this?
    Seems to only happen in Sport mode, but driving the SG without sport mode is really hard.
    White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
    I like Coupes.
    Washington, D.C.
    S54 e36/8
    Anecdotal comment here, but I had an issue where my e39 M5 would stall out coming to stop signs and it ended up being a cracked 90 degree plastic elbo between the V of the engine that is part of the idle control valve system. I've never looked at or diagnozed anything like this on our engines, however, your symptom immediately made me think of what I experienced.
    Could be something in this diagram: https://www.realoem.com/bmw/enUS/sho...diagId=13_1749
    Or your Idle Control Valve needs a bit of a cleaning: see youtube for what to spray in it and how to shake it to clean it out.
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    +1 icv
    Feb 2009
    Charlotte, NC/Denmark
    2K Z3 2.8
    OK, so I'm gonna sound like a total dope here but here goes:
    1: Did ///M Coupe and Roadster get sport mode? Or was it determined by year?
    2: What is an SG?
    Zed's dead baby. Zed's dead.
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Quote Originally Posted by CoconutPete View Post
    2: What is an SG?
    1. S54 powered cars had sport mode, similar to E46 M3s.
    2. Steel Gray, S54 only color.
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Feb 2014
    Galt,CA
    2002 M Coupe
    Quote Originally Posted by TexaZ3 View Post
    Well, my steel gray S54 doesn't seem to have anything that looks like a sport mode, unless I stupidly don't recognize it. I didn't see anything in any manuals about it either. Where is the switch that activates it?
    Marty
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by MartyBtoo View Post
    Marty
    There wasn't a factory "switch" to enable sportmode in the '01/'02 Coupe & Rdstr, only the 4-seat M3s. I don't remember if the Z4Ms had that enabled...
    But in the case of the '01/'02 cars, the function does exist in the DME, and it's just a matter of "grounding" pin-15 on connector X60004 to toggle it on or off. I happen to have one of the few controllers that DWM made up, that allows me to enable sportmode, and it will remain in the "last state" when the engine is turned off & restarted (if it was "on" then it is "on" again when retarted). It also illuminates the "SPORT" icon in the instrument cluster*.
    * now WHY do you suppose BMW would design the cluster with a "SPORT" icon, but no switch to activate it...?
    Fort Worth, TX
    Oh, right. I forgot that there wasn't a factory switch.
    Washington, D.C.
    S54 e36/8
    For anyone who is interested in DWM's controller, he shared his BOM and the simple code that makes the controller work. I've also posted a pretty comprehensive set of drawings/instructions on how to wire it up without actually cutting or splicing into any existing wireing. It can be done 100% plug and play with the right pins and connectors.
    * probably for the same reason our S54's made less power and had taller gears...couldn't be as cool as or as fast as the e46 M3!
    We've completely threadjacked mpire
    Oct 2007
    VA
    00 Mshoe
    5 S52 SG Coupes exist in NA. They were and individual order option.
    But more on topic, I'd also be looking at the ICV system.
    I would check the operation of the clutch switch
    PRICE CUT on ALL FABRICS
  1. Sports mode on Auto trans, problem?
    By Kevin@KEST in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-15-2006, 04:56 PM
  2. Whats up with Sport Mode and Manual Mode
    By Ryan328i in forum 1991 - 1999 (E36)
    Last Post: 12-04-2002, 06:03 PM
  3. Engine Dies
    By josborn in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-12-2002, 08:46 AM
  4. 328 Engine Dying
    By AZZ in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-04-2002, 05:55 PM
  5. how fast can i go in sport mode?
    By Bmw Rollin' in forum 1991 - 1999 (E36)
    Last Post: 06-28-2001, 10:53 PM
