Results 1 to 6 of 6
Thread: Weird lighting issue
    Aug 2009
    Ontario, Canada
    2017 M240iX
    Canadian 2011 128i.
    Got the light warning on the cluster. Here is the behavior:
    Light Tail lights Side Markers Front Markers Inner headlights Outer Headlights Pass Angel Driver Angel
    Park on OUT on -- -- on OUT
    Low on OUT on -- on on on
    High on OUT on OUT high on OUT
    Most confused by the drivers angel eyes. As far as I know everything was fine "yesterday" and no warnings were being thrown.
    Inner headlights are always out.
    Very strange set of failures to happen all at once, any ideas?!
    F22 '17 M240iX
    E82 '11 128i Msport
    E90 '09 323i
    E46 '99 323i
    E36 '98 328i Msport
    E30 '88 325iX
    also, for her:
    F48 '17 X1 Msport
    E83 '09 X3 3.0i SI
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check the voltage at the jumper post located under the red plastic cover under the hood. Use the engine as the ground. Check it and report back you findings when the:
    - car is off (hood open, obviously)
    - accessories on but engine off
    - engine idling - engine revving at 2000rpm.
    Aug 2009
    Ontario, Canada
    2017 M240iX
    Off 11.9
    Accessories including headlights and ignition 11.4
    Running at idle mid to high 14’s
    Running at 2000+ high 14’s almost 15
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Your battery is shot! A fully charged battery will read about 12.6VDC. Your alternator is really pumping out the juice in an attempt to charge the battery. Don’t forget to register the new battery. Our cars have an intelligent charging system whereby they use a different charging profile fir new batteries redid old batteries.
    Aug 2009
    Ontario, Canada
    2017 M240iX
    Can I register it myself with Carly or Bimmercode or ??
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    You may be able to do so with Carly. BimmerCode doesn’t have that capability as far as I know. Contact the people at BimmerCode to find out.
  1. Weird light issue
    By InfectedKetchup in forum 1991 - 1999 (E36)
    Last Post: 12-09-2017, 10:38 PM
  2. Weird light issue
    By CC325i in forum 1991 - 1999 (E36)
    Last Post: 07-27-2012, 10:12 PM
  3. weird lighting issue
    By e30nate in forum 1988 - 1996 (E34)
    Last Post: 07-02-2011, 11:03 PM
  4. weird lighting issues.
    By Brewtech in forum 1976 - 1989 (E24)
    Last Post: 08-29-2008, 02:22 AM
  5. Weird (minor) dash lighting issue
    By GuinnessDraught in forum 1988 - 1996 (E34)
    Last Post: 08-21-2006, 09:11 PM
