my 2013 750li engine faltered at 48,000 ml
I want to put a new engine in it . of course Bmw factory too expensive and too long to wait.
what other models have the same engine.
and other suggestions would be sooooo useful
thank you in advance,
Hopefully, hopeful Hope
you posted in the Forum: BMW Employee and Technician Talk, that is not to ask technical questions,
I will move it to the correct 7 sub forum
all models using that engine https://en.wikipedia.org/wiki/BMW_N63
If your 2013 750i was manufactured 07/2012 or later, it will have a N63TU (N63B44O1) engine.
Not the earlier N63 engine
Ditto…a build date would help us help you better. But you can use one of the online part database sites like www.realoem.com or www.bimmercat.com…input the last 7 digits of you VIN (which will determine if you have the N63 or the N63TU engine…then go to the ENGINE diagrams and CLICK on the 11 digit part number. This will list all other BMW models that use the same engine as well as any other part nbrs that are retroactively exchangeable or superseded exchangeable part number.
Examples:
- N63: https://www.realoem.com/bmw/enUS/par...&q=11002296773
- N63TU: https://www.realoem.com/bmw/enUS/par...&q=11002346944
Once you determine the correct engine, go to car-part.com to locate said engine in junkyards near you, including pricing. A quick search shows used motors available from $4500.
