Results 1 to 2 of 2
Thread: 4 Codes and ABS/ASC light is on while at track day - Need help!
    Aug 2017
    Hendersonville, TN
    1997 328i Sport
    Did a track day on Saturday at NCM and near the end of the 4th session, my ABS/ASC lights came on and stayed on so I pitted, turned the car off and let it cool down while I packed my stuff to make the 55 minutes drive home. When I started it the lights were off and I could toggle the ASC on/off with the button but about 5 minutes later just the ASC light came on and stayed on. About halfway home on the interstate the engine started to hesitate a little and then stopped. It did this a few times so when I got to my exit I popped the hood to give it a look over and saw nothing obvious. When I started the car again the check engine light was on and I continued home. I didn't have anymore engine hesitation/missing but could feel a pinch of power loss on the low end when accelerating from a stop. I scanned for codes this morning and got these:
    P0340 Camshaft sensor inlet signal
    P1550 Idle speed control valve closing solenoid control circuit electrical
    P1509 Same as 1550 but opening instead of closing
    P0161 Faulty Rear Heated Oxygen Sensor Bank 2 · Rear Heated Oxygen Sensor Bank 2 harness is open or shorted
    All of this crap with the ABS/ASC happened while under full throttle on a straight away. I left ASC on all day due to cold track temps so it got a workout. Where do I start? Reading about the ABS/ASC looks like it could be a dirty or faulty wheel speed sensor or brake position (?) sensor on the brake booster. Could this issue happening first be related to the series of codes that happened later?
    Any help appreciated!
    Mike
    1997 328i Sport, 5 speed
    2013 X5
    Mar 2022
    Sacramento CA
    1997 328i
    My 97 328i is doing just about the same thing. Did you ever find a solution?
  1. ABS & ASC Light on Many Error Codes 1996 840Ci
    By Beagle2 in forum 8 Series (E31)
    Last Post: 05-27-2015, 08:09 AM
  2. P0500 check engine code and ABS/ASC light on
    By wahwill in forum 1992 - 1999 M3 (E36)
    Last Post: 08-26-2012, 04:38 AM
  3. ABS/ASC lights 00082 Fault code
    By Tommay85 in forum 1991 - 1999 (E36)
    Last Post: 05-19-2010, 12:16 PM
  4. ABS/ASC lights 00082 Fault code
    By Tommay85 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2010, 11:10 AM
  5. ABS/ASC lights on, NO codes set
    By slavichm in forum 1995 - 2001 (E38)
    Last Post: 03-13-2010, 03:21 PM
