Results 1 to 11 of 11
Thread: Looking for replacement steering box
    Jul 2014
    North
    1992 E31 850i
    Hi all,
    I'm in need of a replacement steering box (new or used).. even a used one I can sent to have rebuilt.
    The BMW part number is 32131138858 Hydro Steering Gear Servotronic. I have done my best searching of the web and come up empty.
    Any ideas/suggestions?
    Jun 2010
    Hyperworld
    '97 840CI
    Is there an award for the longest lurk?
    ** edit **
    Possible typo? 32131138868, a reman with original plate 32131138691
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    pls add to your profile BMW model, type, engine , built year and month, then it is easier to help you and find the correct p/n. Also VIN would be helpful in this case. E31? 840, 850, M70, M73 etc
    For example here is a reman one in Germany, Lenkgetriebe for BMW 850CSI (8054991122, ZF 290630, 132131136818, 32131138858 EURO 1489 plus core charge https://www.gts-shop.de/Lenkung/Lenk...131138858.html
    or here from USA https://parts.bmwnorthwest.com/p/BMW...131138858.html
    Jul 2014
    North
    1992 E31 850i
    �� Nice. I deserve that one lol
    Quote Originally Posted by Hyper View Post
    Sorry about that. Its a 1992 850i.
    I have found this service that will rebuild a unit for $550, so I was hoping to find something cheaper than the ones you had found which are pretty pricey.
    https://www.buyautoparts.com/buynow/82-00096_r
    My issue is the dealer won't remove my existing unit in order for me to send it off to be rebuilt as we will be stuck on one of their lifts for the duration of the wait.
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    Quote Originally Posted by roberto145 View Post
    Hi all,
    If you can’t find a box, you could buy an e32 refurbished servotronic box. Refurbished (assume just resealed/painted) go for $500-600. The ratio is different, and you need a different part # pitman arm to fit to it, but if all else fails..
    This is what I fitted to my car, but I will be fitting Quick Arms to correct the ratio difference.
    Jan 2005
    Japan
    https://www.car-part.com/ select car part, your area, zip code and then probably you will find a used one.In case there are only leaks, there are seal kits available. there are presently 3 for E31 850, 1 $500, others you have to call
    also post here in the E31 forum in the parts wanted/for sale what you want to buy, condition...., even defective, just needed as core, maybe someone has one.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    I have had units rebuilt here:
    https://benchworksteering.com
    Regards,
    Brian
    Cave Creek, AZ
    Oct 2002
    Cold Snowy North
    Misc.
    Benchworks rebuilt one for me; I have not yet had a chance to install it though
    Sep 2021
    Stayton, Oregon
    1991 bmw 850ci
    Jay Stratton website Jays BMW parts rebuilds them along with many other parts. Does a fine job at a very nice price.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Jay does not do the steering boxes, he does the pumps. Benchworks is the place for the boxes.
    Nov 2010
    Santa Ana, CA USA
    1988 m6
    Quote Originally Posted by cdrusn View Post
    CDRUSN,
    Thank you for mentioning me,
    I do Leak Repair, on the '91 - e31 Hydro PS Gear Box, I replace all of the seals, and do a Lash Adjustment,
    Please view my new Website Jay's BMW Parts (jaysbmwparts.com)
    Most low mileage HPSGB's do not need a full rebuild, that is what the lash adjustment is all about!
    It is beacuse they leak after 20 years, as the rubber o-rings loose their elasticity,
    and the rubber fails to rebound, the round cross section is now egg (oval) shaped,
    and it has now changed its dimension, while under compression, for 20 years!
    And for Cartoonz, please review my website, my price is less than Benchworks.
    Jay
    '88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
    My NEW Website, Link : https://www.jaysbmwparts.com
    Booster repair
    A/C Wingcell Compressor leak repair
    e31 Door Handle Fix,
  1. replaced steering box, what a ......
    By south42 in forum 1988 - 1996 (E34)
    Last Post: 12-11-2011, 12:11 AM
  2. replacing steering box on 540- help?
    By CarlfromBoston in forum 1988 - 1996 (E34)
    Last Post: 09-25-2011, 07:43 AM
  3. Replacing steering box...any new lines/hoses to do too?
    By 4500 RPM in forum 1988 - 1996 (E34)
    Last Post: 03-13-2011, 07:36 PM
  4. Looking to replace steering column, HELP!! (97 M3 Sedan)
    By mse678 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-19-2009, 01:19 PM
  5. Question about a replacement steering box for my touring
    By hutch555 in forum 1988 - 1996 (E34)
    Last Post: 07-10-2009, 06:29 PM
