Results 1 to 4 of 4
Thread: Vanos pressure accumulator leaking, can i disconnect?
    Lebanon
    E30 M3 S50B32
    Hey guys,
    I have an oil leak that seems to be coming from the top of the pressure accumulator where the line goes in, not sure if it's the line that needs replacement or the accumulator or what.
    I tried to remove the line but the accumulator doesnt have the brackets that hold it in place, so holding it in my arm and turning the line's nut only made the line warp.
    Not sure what to do to remove it without its brackets holding it, i was thinking if the accumulator only provides pressure for start-up rattle, since i was able to remove the other end of the line that goes into the vanos unit, maybe i could just put a bolt there and close it shut. Thoughts?
    1987 BMW M3 S50B32 engine swap
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    could you fix this problem?
    Lebanon
    E30 M3 S50B32
    Quote Originally Posted by shogun View Post
    At the top of the accumulator there's a place where you can put a spanner to hold it while you turn the pipe's bolt without the accumulator turning with it.
    As for my car, the leak was behind the bolt in the line, so i had to cut the line near the vanos and get it welded shut til the new line arrived.
    I've been driving the car, but no WOT or pushing it above 4k rpm.
    I got the new line but it looks like it might be a PITA to swap the lines, from the engine pic i found below i think i might have to remove the water pump pipe as well, can anyone shed some light?
    Also, does anyone know if running the car without the accumulator would cause damage? When the vanos pressure is lacking it should supplement a little, so without it, the vanos response times would be slightly lower, but nothing damaging to parts i guess. The thing is, having the accumulator i think would lower the overall pressure of the system at its peak since part of the pump's pressure is going to the accumulator to push the spring. What i dont know is if this pressure increase is high enough to damage any vanos related parts, o-rings etc?
    Lebanon
    E30 M3 S50B32
    Just to update the thread, i've been looking at the line and it looks like the only troubling part is the TPS bracket which comes off easily and the aluminum pipe that comes out of the thermostat housing/pump rubber pipe.
    I think ITB removal isnt needed to change the line. I'll be changing the water pump soon so hopefully can change the line at the same time.
  1. E32 brake bomb (pressure accumulator) replacement
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 10-20-2022, 06:33 AM
  2. Running without Vanos Pressure accumulator
    By madspeed in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 07-25-2011, 11:13 AM
  3. Bad Vanos oil line leak
    By bmw328power in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-13-2008, 12:46 PM
  4. Fuel Pressure Regulator Leaking...
    By coheed in forum 1991 - 1999 (E36)
    Last Post: 10-18-2005, 07:43 AM
  5. Gas Tank Pressure & gas leak problem
    By MFaust in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-17-2004, 03:07 PM
