Originally Posted by
boostinm3
Hello,
I need to disable TPMS and enable FTM on my e84 BMW X1. I was able to disconnect physical TPMS RDC module, but don’t have the computer software to connect and code out TPMS and enable FTM. Does anyone have the computer software to connect to my car to perform numbers 2 and 3 below? I’m on San Diego. Thank you
1) Disable/disconnect physical TPMS RDC module. The specifics are further down in this thread, but basically it should be under the car and behind the rear axle.
2) Code OUT $2VB and ADD IN $265 in the VO.
3) Change the following codes in CIC, KOMBI, and XDSC:
CIC: RPA_CIC
aktiv
CIC: RDC
nicht_aktiv
CIC: RDC_SAFETY
nicht_aktiv
KOMBI: RDC_ALIVE
nicht_aktiv
KOMBI: MMI_ENA_RPA_RDC
aktiv
KOMBI: RDC_VERBAUT
nicht_aktiv
KOMBI: DSC_MIT_RPA_CC
aktiv
KOMBI: RDC_DISP_SWITCH
nicht_aktiv
XDSC: AUSSTATTUNG_RPA
aktiv
Then you can go into the status menu. If you go to the Flat Tire Monitoring System tab, it should see there is an error. Just go to the 2nd tab and reset it. Then you should see green in all corners.
RPA FTM is now working on my US-spec E84.
