Results 1 to 3 of 3
Thread: 07 550i 4.8L VANOS solenoids which plugs go where?
    Oct 2021
    Tx
    2007 550i 4.8L
    2007 550i with the 4.8L V8
    There are 4 total solenoids on the front of the engine, two per cylinder head.
    Which plugs go where?
    Longer wiring on top? Or bottom? And on both sides right?
    Car came in all taken apart after a (supposed) timing chain replacement job, car wasn't ever reassembled afterwards(yup..basket case headache job) and when reassembled, once started ..it ran like crap. Guessing the connectors for the VANOS solenoids are probably backwards (I hope..if not there's bigger headaches I suppose..)
    I have a basic scan tool, will scan it in the morning.
    Oct 2021
    Tx
    2007 550i 4.8L
    Right now I have them plugged in as follows:
    Passenger side cylinder head: connector with longer wiring plugged into the top solenoid. Connector with shorter wiring plugged into the lower solenoid
    Driver side cylinder head: connector with longer wiring plugged into the bottom solenoid. Connector with shorter wiring plugged into the upper solenoid
    I've read and searched a lot and it's really hard to find pics of the n62 showing clearly which connector goes where. I may try swapping them but I don't have any codes having to do with VANOS.
    I got p0393 and p0341 and a bunch of misfire codes though
    I'm checking the camshaft position sensors wiring now.
    Oct 2021
    Tx
    2007 550i 4.8L
    Ok so after more searching of Google images and eBay listing, and looking really hard at the harness on those engines...i found that I did have them correct. Just an FYI for anyone wondering or anyone in the future..👍
  1. Need help from S52 owners, VANOS solenoid wiring plug location....
    By 2391533 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-26-2013, 03:13 PM
  2. Replies: 3
    Last Post: 06-10-2009, 07:23 PM
  3. where does the vanos solenoid plug into?
    By redforcedbmw in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-04-2008, 12:38 AM
  4. where does the vanos solenoid plug into?
    By redforcedbmw in forum 1996 - 2003 (E39)
    Last Post: 01-03-2008, 04:56 PM
  5. Vanos solenoid, new plugs, or both?
    By Speedlimits? in forum 1992 - 1999 M3 (E36)
    Last Post: 04-21-2005, 01:09 AM
