Results 1 to 2 of 2
Thread: BMW F30 Drivetrain Malfunction Error codes P1290 & P0171
    Sep 2016
    West Chicago
    2013 BMW 328i Xdrive n20
    Hello, all I've been getting a check engine light and a drivetrain error for the past two weeks it comes and goes but 90% its stays.
    It started when I decided to fix a very small boost leak. I replaced the boost/charge pipe and noticed a small leak. I couldn't determine if it was the charge or boost pipe so I decided to take both of them out and install them again when doing so I had to unplug a bunch of harnesses and clamps take off my engine cover for easier access. After I put them back on the boost leak was solved it was driving fine for that day the next day I had a check engine light and a drivetrain malfunction sometimes I get one or the other but overall it reduces my power I get codesP0171 and P1290 I clear the codes and usually the P1290 stays. I've opened my hood at least 10x for every day since this has happened. (I am running a JB4 tune but have unplugged it in case that was the cause but it isn't, it remains unplugged atm.)
    (2013 BMW 328i XDrive)
    Solutions I have tried:
    Retightened vacuum lines
    Clean Mass airflow sensor
    Replace Inlet pipe
    check wiring harness again.
    Jul 2004
    Houston, TX
    36 Cylinders
    I would read BMW manufacturer codes first and not P codes.
    A smoke test is what will guarantee no leaks.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. f30 DriveTrain Malfunction - no major loss of power, no CEL, no codes being stored.
    By BigDirty in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 09-18-2019, 01:01 PM
  2. Rough Idling / Drivetrain Malfunction Error / No Start
    By precisionintime in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 01-16-2018, 07:17 AM
  3. 2004 BMW X5: Braking Lining Error Code, what is wrong?
    By sphinxica in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 10-12-2011, 03:18 PM
  4. Bmw e60 charging fault error code
    By bimmermadder in forum 2004-2010 (E60,E61)
    Last Post: 08-02-2011, 04:43 AM
  5. 2001 BMW 530i Sport (E39) Error Code C3401 C3110
    By Scorpio2010 in forum 1996 - 2003 (E39)
    Last Post: 09-01-2010, 05:28 AM
