Hi,
I had repeatedly problems with the pump motor of my DSC Unit. Now I could get a used hydraulics block with motor in good condition and I want to swap these parts but keeping my old ECU. The Part numbers are different but the dimensions are identically and the new hydraulics block is also engraved with „1078“ … so I think this will match.
I read the hydraulic valves must be calibrated when used with another ECU, is this true? Which Software is needed to perform this calibration or can this be done at the BMW dealer? I know bleeding has to be done with inpa, I did this before.
Alternatively, I could swap the complete unit (ECU, block and Motor), then I had to code the new ECU to my car. Is this easier with common software (Inpa and such)?
Hi again,
got a list of possibly compatible DSC Parts of 6-Cylinder E9x, with the crimped pump motor (listed at end of this thread). I bought a unit with the number "1078" on the hydroblock (just as on my old block) and installed my old ECU on it. Basically, I was following this video: Link
After building in the fixed unit, I bleeded the system using INPA and made a testdrive. No failures were coming of, ABS, DSC and DTC were working fine. Calibration of DSC-ECU or its hydro-valves was not asked by the car. Everything is lookin fine.
The guy in the Video throw in, that a calibration of DSC might be required if there is active steering and/or e-powered steering is in place. My car does not have one of these, maybe it works without any calibration at my car. If not, I will update here ...
Greetz ---
4516777162, 34516779893, 34516775396 34516771697 34516770588, 10.0961-0838.3 10.0212-0081.4 10.0613-3414.1, 3452678476601 3451678476501 10096108613, 10021201794 10061336721 3452 6784766-01, 3451 6784765-01 10.0961-0861.3 10.0212-0179.4, 10.0613-3672.1 3452679014701 3451679014901, 10096108703 10021203494 10061339971, 3452 6790147-01 3451 6790149-01 10.0961-0870.3, 10.0212-0349.4 10.0613-3997.1, 3452783935101 34517839351 10096108533, 3451 7839351 10.0961-0853.3 10.0212-0117.4, 10.0613-3488.1 3452784103801 3451783907901, 10096108583 10021200884 1078 3452 7841038-01, 3451 7839079-01 10.0961-0858.3 10.0212-0088.4, 3452784110901 3451784110901 10096108553, 10021201624 10061335841 3452 7841109 01, 10.0961-0855.3 10.0212-0162.4 10.0613-3584.1, 34506777160 6777160 6780235 34506780235, 34516779891 6779891 34516778486 6778486, 1078, 6778236 34516778236 6778236-01, 3452677823701, 7841954 34517841954, 7841953 34517891953, 7841954 34517891451 3451677848401 3452677848501 10096108503, 10021201404 1078 10.0961-0850.3 10.0212-0140.4, 3452676916402 3451676916203 10096108293, 10021201044 10.0961-0829.3 10.0212-0104.4, 3452677148901 10096108203 10.0961-0820.3, 10.0206-1051.4, 3452677606701 3451677606601 10096108513, 10021201024 10061334921 3452 6776067-01, 3451 6776066-01 10.0961-0851.3 10.0212-0102.4, 4 10.0613-3492.1 3452677823701 3451677823601, 10096108383 10021200814 10061334141, 3452 6778237-01 3451-6778236-01, 34506777164 6777164, 6771490 34516771490 6775394 34516775394, 6778484 6778485 34516778484 34526778485, 7844050 34517844050 7838391 34517838391, 6784812 34516784812 6775387 34516775387, 34506784811 6784811 7844050 34517844050 7838391 34517838391 3451-6784765-01 6784765
