Results 1 to 10 of 10
Thread: Supercharged e36 M3 idle A/F
    Oct 2007
    Montreal, Quebec, Canada
    1999 BMW M3 COUPE
    Hi all,
    There is an idle situation that I try to resolve. Idle is bouncing a bit and A/F is changing. One affecting the other.
    Here's a link to the video:
    https://www.dropbox.com/s/qme85dodis...75456.mp4?dl=0
    Does somebody have a clue?
    Jul 2004
    Houston, TX
    36 Cylinders
    I'd say you either have a vacuum leak or the tune needs a lot of work.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2007
    1999 BMW M3 COUPE
    Thanks for comment,
    I've been pressurizing the system to about 1psi with a smoke machine and nothing came out so I figure it's not a leak
    Tune's from RK tunes, should be on point. Everything's good unless the idle. This idle is just annoying
    anymore ideas?
    thanks
    Jul 2004
    Houston, TX
    36 Cylinders
    If your throttle body is fully closed at idle as it should be, this is completely out of the tune.
    -Abel
    Oct 2007
    1999 BMW M3 COUPE
    Throttle is fully closed and cleaned 2 weeks ago. TPS signal is at 17 percent when throttle closed. I dont know if this is a normal reading. Signal goes smooth to 100 percent.
    I understand that the tune is programmed to change parameter with signals from sensors. For a change of parameters, somethings gotta change. But with no input from my end, what could be changing sensor datas?
    Thats what I'm trying to figure
    ATL
    '91 325i
    Almost completely certain its the tune. Factory computer does change AFR up and down as it idles, but way smaller changes. I am pretty sure this is whats happening here but the bigger injectors make it do way larger swings. For some reason nearly everyone thinks a wide open dynojet "tune" is all you need. In their defence, you also shouldn't expect an $800 recalibration have the refinement of a what a team of engineers did in the first place.
    Harrison Motorsports
    Motion Control Suspension
    Daytona M3
    Oct 2007
    1999 BMW M3 COUPE
    Thanks for the input Pavlo,
    After all the tests and parts replacement I've done, I am leaning towards the tune also. I'm sure it could be easily fixed though because 42 lb injectors are'nt big injectors compared to bigger set-ups running way more hp numbers and idling better than my car. I'm going to log the car with bmw logger and send the datas to my tuner and hopefully find the culprit!
    Aug 2011
    Los Angeles
    my brother's ti
    for forced induction, you should be doing a boost leak test, not a smoke test. you need a boost leak tester to force at least 15 psi of compressed air in the system and then spray all connections with soapy water. you will be amazed at the leaks you will find.
    Jul 2004
    Houston, TX
    36 Cylinders
    Right, but at idle, none of that matters.
    You can start to progressively close the idle control valve out of the tune, since the factory control of ICV doesn't match when there is a compressor making a little bit of extra air at idle.
    Other considerations: wrong injector dead time placed in the tune; physically the MAF is in a bad location or not experiencing laminar flow, etc.
    -Abel
    Mar 2022
    Rockwall
    1998 M3
    My vote is: out of tune, as well, did you figure it out or get it fixed ?
  1. Replies: 4
    Last Post: 03-29-2016, 02:02 AM
  2. E36 AA Supercharged E36 M3 Track Car | Castro Motorsports | Autotalent
    By nlakind in forum 3 series & Z Series
    Last Post: 06-28-2015, 04:10 PM
  3. E36 WTB Dinan Supercharged e36 m3, prefer local sale CA, AZ, NV..
    By CSLBILL in forum 3 series & Z Series
    Last Post: 11-06-2013, 11:40 AM
  4. E36 FS: AA stg 2 supercharger e36 m3
    By euroguy in forum Engines, Performance Parts & Software
    Last Post: 10-24-2011, 10:36 PM
  5. E36 WTB: TURBO or SUPERCHARGED E36 M3 COUPE! (SOCAL)
    By sahane36m3 in forum 3 series & Z Series
    Last Post: 10-24-2011, 02:03 PM
