BAVToys
Results 1 to 5 of 5
Thread: E46 Bosch / AL bi-xenon poor light output
    Oct 2016
    SC
    330i
    I have purchased a set of Bosch / AL bi-xenon assemblies with the metal bowls to replace my burnt out ZKW bowls. I noticed the drivers side output is extremely weak so I replaced the bulb with a new oem D2S bulb but that did not solve the issue. Any suggestions as to what might cause poor light output from the Bosch projectors? These lights were supposed to solve my poor light output issue 😭
    Oct 2016
    SC
    330i
    Reading further into this I'm seeing it could be a failing ballast which would cause poor light output. I guess my question is, are these Bosch / AL projectors prone to any common failures (similar to the ZKWs) which I should be aware of before I go and swap the ballasts?
    (forgot to mention, the lenses have been sanded down and are crystal clear)
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    I've never seen ballasts fail this way to be honest, but I have plenty of spares for facelift AL assemblies, PM me if you want to borrow for testing. You can also swap ballasts left to right and see if the issue follows.
    Oct 2016
    SC
    330i
    Thanks for that Mless. I believe the issue is a burnt out bowl, as is common with the zkw's. Mine being Bosch/AL I figured they would not have this, issue but apparently it can happen after some time.
    Peoria, AZ
    Chrome coating does deteriorate over time and gets cloudy/milky indeed.
  1. E46 Angel Eyes-Xenon Poor Lighting?
    By GiuseppeD in forum 1999 - 2006 (E46)
    Last Post: 01-18-2019, 01:55 PM
  2. e46 Facelifted Halogen to OEM AL Bi Xenon HID Retrofit
    By Fanatic10 in forum Lighting sponsored by BAVToys
    Last Post: 10-26-2018, 10:38 AM
  3. Replies: 4
    Last Post: 02-25-2013, 08:41 PM
  4. E46 WTB: AL Bi-Xenon
    By Infamouscrew02 in forum BMW Parts Wanted
    Last Post: 01-17-2013, 05:11 AM
  5. E46 BMW E46 Coupe/Convertible Bi-Xenon Headlights OEM
    By ttgxc in forum Exterior Lighting & Body Parts
    Last Post: 02-24-2010, 11:37 AM
