I swear I've seen the answer to this elsewhere and can't seem to find more than a relay diagram, so apologies if I'm missing the answer to this already.
My hazards all work fine, all bulbs flash as intended and all is great there. My left turn signal works fine. Then when I go to use the right-- nothing.
I've checked the K16 hazard relay and had a spare, so swapped it just in case and am seeing the same result.
In both the trunk and engine bay fuse/relay compartments, I'm not seeing anything specifically for right and left turn signals and am not sure what else it might be.
Is there a non-descript fuse I'm missing? Another relay location?
Any advice or tips are appreciated!
My guess would be the turn signal stalk.
If all bulbs work when hazards are engaged.
Had to take it in to get this confirmed, but yep— it is the turn signal switch stalk. Found an OEM one on ECS and order placed. Thanks @peterjk
