Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: s50b32 stuck at 326 bhp....
  1. #26
    The Netherlands
    DE-spec E36 328i/M3 cab
    Just chime in here to say "Cool car!"
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  2. #27
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Any updates?
    88M3 AW 43k miles Project FS
  3. #28
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Nice to see an engine upgrade thread. Im a little late to the party also. When I was playing with my S50B32 in NA form, I basically had a standard engine with Schrick 284 cams and standard plenum, with optimised mapping, cold air and aftermarket exhaust (standard headers) it made 285rwhp on dyno dynamics dyno, so 326 is not so bad outcome, especially on pump fuel. With that extra comp you may be timing limited so perhaps running flex fuel (e85) you could feed in more timing to realise more power across the range without going silly high with the rpm. As discussed, standard headers may be causing a small restriction. Spinning up the RPM may also realise more power but with the long stroke design may be putting lots of load on the engine especially north of 8k rpm.
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  4. #29
    Jan 2002
    Central Pacific
    Quote Originally Posted by GazM3 View Post
    ... basically had a standard engine with Schrick 284 cams and standard plenum, with optimised mapping, cold air and aftermarket exhaust (standard headers)
    Gaz, that's where I am (still). With the tuning, did the car respond well when street driven? Meaning, not balls to the walls, lower rpm usage, etc. I'm curious if the 284s can be 'tamed'.
  5. #30
    Dec 2005
    E24, E34 x2, E36
    Quote Originally Posted by MauiM3Mania View Post
    it was hard to quantify as when I done the cams I done the LW flywheel at same time. Lost a little bit of bottom end but the top end was very good. I also used the racelogic and got a 0-100kmh time of 5.0sec without 1 foot rollout, and with the 3.62 diff didnt quite have the legs so needed a gearchange at about 96kmh which added no doubt around 0.3sec to the time.
    I found I could still use 6th to about 55kmh, whereas before i could drop the revs stupid low around 35kmh and 800rpm it would still haul 6th
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  6. #31
    Mar 2010
    Sugar Land & Houston, TX
    4 e21 BAURs; 2011 B7,
    Quote Originally Posted by yannick1993 View Post
    hello.
    I have recently built a s50b32 in my e28.
    specs of the engine:
    12.5:1 JE 87mm pistons
    complete rebuilt head
    284 degree catcams
    ZRP conrods
    rebuilt crankshaft
    rebuilt vanos
    EMU management
    CSL style carbon intake
    dw 550cc injectors
    alu flywheel
    custom equal length stainless headers
    simons dual 50mm sport exhaust with H pipe
    everything is tuned on the dyno with these results as you can see in the dyno sheet. (326 bhp and 340 nm )
    I know it is not bad, but with all these mods I did expect some more power.
    do I have a bottleneck somewhere or why isn't it producing more power?
    one note here, the fans weren't pointed on the air intake which resulted in a IAT of around 70 degrees.
    we have tried tweaking vanos map, ignition timing and VE values. but all with no result. The guy who has done the dyno mapping has a lot of experience on s50/s54 mapping, so I don't think that was the problem.
    anyone...?
    Verstuurd vanaf mijn SM-A526B
    Have you tried the factory plenum. I've been told by many during my build that BMW put a lot of research and dollars into designing their plenum and that I'd likely loose HP if I modified or changed it. Sorry for the late reply but I've been off the board for too long. Kindest regards,
    Awesome build!
  1. Gas needle is stuck
    By Stylin in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2003, 03:14 AM
  2. My gas needle is stuck
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 11-19-2001, 09:17 PM
  3. Sunroof was stuck! Bleh!
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 08-15-2001, 04:12 PM
  4. Calipers Stuck on Rotors need help.
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 07-11-2001, 03:45 AM
  5. There's a Bird stuck flying around in my garage...
    By Black Majik in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-18-2001, 10:52 AM
