Hello all,
I recently purchased a set of style 19s from someone local to me for pretty cheap. I am rebuilding them and will try to polish out the lips. However there appears to be some bite marks left in the outer lips as if someone mounted tires backwards.
I wanted to get your opinions on whether you think they be able to be sanded back. I am planning to start with a 80 grit sanding block to remove the high spots, there are plenty of them, then move up to 160, 240, 400 etc. 2000 wet sand and polish.
If they are not polishable then i have another route i plan to go, but i want to try this first.
The picture below is of the worst of the set. you can see there are several sets of bite mark indentations in the lips that i want to try and sand back, but if its a lost cause and i should just use filler and get them painted then i wont even attempt.
Thanks in advance for the help/advice.
https://photos.app.goo . gl/JatdwxrjPrXj3KeL9
please remove the spaces above in the link, the forums are moronic and not allowing me to post link, for whatever reason they are replacing the goo . gl part with stars......
SMurfBlUe 96 328i - Gone
WRB On Gold BBS 02 WRX "Stage 3" - Gone
Black 93 325is on Roadstars - getting ready for turbo
White 2010 WRX IAG Stage 2 TUFF 400awhp daily
