Hey there!
All right, folks, I'm selling what could be turned into a BMW e36 M3 (or other) big brake "kit". I add the parentheses as this was purchased from multiple vendors and as of now the calipers purchased do not work with the Brake Revolution e36 bracket also purchased. The Wilwood calipers are used (obviously) but in great condition.
This bundle is for someone that isn't afraid of a little fabrication work and has experience working with custom aftermarket parts. This kit comes with:
Wilwood 4 piston calipers
E36/Z3 brackets (Again, these don't fit the caliper bolt patterns, FYI)
Hardware for installation
E46 Rotors (New)
New brake lines
Two (2) sets of new brake pads
If you went out and tried to purchase these parts from manufacturers they would run you into the thousands. This is a much less expensive (albeit used) way to upgrade your BMWs brakes.
Link to CL add (with photos): https://washingtondc.craigslist.org/nva/pts/d/springfield-wilwood-big-brake-kit/7374107730.html
ad is expired
