Copied from Amazon ad for 312 393
This product fits this position on your 1992 BMW 525i:
- Front
Notes: INSERT~E34 BODY - ALL w/SPORT SUSPENSION (w/LEVELING SUSPENSION) - ALL w/SPORT SUSPENSION (w/o LEVELING SUSPENSION) - ALL w/STANDARD SUSPENSION (w/LEVELING SUSPENSION) - ALL w/STANDARD SUSPENSION (w/o LEVELING SUSPENSION)~E34 BODY - ALL w/M-TECHNIC
They most definitely work, quite well, and I did point out to the OP that he should consider using the other ones and the V3 top mount when he makes his purchase. I got mine lightly used, and very cheaply, and mentioned them to him as alternatives to Koni and Bilstein for a decent ride and excellent function. I'm guessing Sachs are not as sensitive to spring length, so their struts work either way.
It sounds like some folks in this thread need to revisit a certain de-bunked myth about lowering springs on stock-length shocks... (from E34.net and confirmed by outside, impartial engineers as well):
"There is a long held myth about so called lowering shocks or shocks designed for lowering springs with reduced travel versus shocks designed for standard or taller springs. The best way to visualize it without physically looking at the shocks side by side is...the only tangible difference is the stroke is shorter in a shock designed expressly for a lowering spring...the throw is shorter. Full jounce position or fully compressed shock position is exactly the same...that is the critical factor for bottoming...where the jounce bumper fully compresses onto the top of the strut collar nut threaded onto the strut housing...that shoulder position is the same for either shock and each shock will identically compress into its cartridge casing. With a standard Boge shock lets say..the throw of the rod internal to the shock is a bit longer..that's all...so the shock is cabable of "extending" farther...at full suspension rebound or when the suspension arms are fully down with a taller spring. With a shorter spring..you don't need a longer throw shock...however..this is the important part...Is putting a standard Boge with longer travel with a lowering spring bad? Absolutely not...you just end up not using the full travel capability of standard shock with a shorter lowering spring... that's all. All the speculation of a standard shock..say Boge..wearing out faster with a lowering spring...is a myth."
Like others, I've purposely run full-length shocks with lowering springs on these cars off and on for 8 years. It still doesn't beat an elegant, street-friendly coil over system, but it sure beats the lack of travel with shorter shocks and springs, especially on American roads.
