Are these still available from the dealer? I'm looking for one. Thanks.
yes those should be the ones from the E36 M3, 328i, M roadster etc.. the OE is Bosch I would buy Bosch either new or reconditioned ones w/ new seals and tested.
OE BMW (Bosch):
https://www.ecstuning.com/b-genuine-...h/13641703819/
https://www.fcpeuro.com/products/bmw...z3-13641703819
https://www.pelicanparts.com/More_In...SVSI=BE36&fs=0
OEM Bosch no BMW Branding:
https://www.ecstuning.com/b-bosch-pa...3641703819~bo/
https://www.fcpeuro.com/products/bmw...28i-0280150440
The dealer will have the OE BMW parts. I wouldn't buy any other brand than Bosch. They dealer probably won't have in stock and will order.
Are any of the rebuilt eBay ones any good? If not can anyone recommend a rebuilder/flow tester?
Marren Fuel Injection, www.injector.com
thanks guys... I ordered a bmw one, but ecs sent me a bosch OEM black one so I'm returning it for a pink remanufactured one.
Bought a GB remanufactured one, and it works great. Now motor is smooth again. Finally all the error codes have gone away...
yeah, I’m all for buying new parts and will usually spend the money to do so for most parts but with injectors it makes no sense. Either send yours out to get new seals, filters & pintles and flow tested or buy remanufactured. Injectors don’t really wear out they have fuel running through them to keep them clean - they can just get clogged.
I assume so, but I'm not sure...The GB remanufactured ones are stock pink ones that have had their black paint stripped.
I would not mix them, just stick to one style.
Are the black ones a direct replacement and can just be installed without any changes to the DME? Did anyone ever buy them and can share long term experiences with the black ones?
I did not want to mix n match. That's why I got a remanufactured OE pink one.
