Page 3 of 3 FirstFirst 123
Results 51 to 66 of 66
Thread: Z4 Quagmire Car
  1. #51
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    I had mentioned I got a used EPS motor to take apart and investigate to see if I could find anything that might be an indicator of what's wrong with my EPS. Obviously the issues with each motor may not be the same, but who knows, maybe I would find something to point me in the right direction. Well, I think I did.
    Here is the motor I procured from a guy on FB:
    Looks like brand new on the outside. I took the cover off the motor to see if there was any filth in there, but it looked perfect, and spins perfectly too. Could not easily disassemble, seems to be pressed together. I removed the screws for the black module box, but that does not seem to come apart easily either. So moved on to popping off the cover, which is also not really intended to be removed, but since I got this to take apart I went after it with some pry tools.
    On closer inspection I see on this motor there are four very thin wire leads that are broken. It would make sense to me that these could be a weak link and cause communication problems with the module, and probably other problems as well.
    Everything is sealed in some goopy clear stuff, but it sure looks like these broken wires can easily be repaired. I will need to pull my column and pop the cover off the motor to see if there are similar broken wires. Not sure why no one else has ever checked this out, it seems to be a hole in the internet knowledge base. Will have to wait until winter for me to deal with it though, as I drive the car from time to time and don't want some hulk taking up garage space all summer.
    In the meantime, I dropped four hundy on these stupid plastic things. What a rip.
    Had to remove the bumper cover again to get at them, but that took about two minutes.
    So basically the car is all back together, almost 100%. Need to deal with seatbacks but that is low priority. In the meantime I will drive the thing. I did manage to get it to pass inspection, so no danger of getting pulled over other than the usual.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  2. #52
    Oct 2012
    Victoria BC Canada
    2004 Z4, 1700 Nomad MC
    Regarding your EPS motor electronic circuit board and the 4 broken wires.
    Having had a good look at the picture you posted…. I would have to say that they aren’t broken but deliberately “clipped” as the likely hood of 4 wires being broken in exactly the same spot on 4 symmetrical corners is 1 to “infinity”…
    Looks to be a deliberate act in the manufacturing process. I wouldn’t be pulling my steering rack based upon this.
    If you do have the sticky steering issue, then adjust the “lash” (is that the correct term?) of the gears as per the now BMW repair procedure that was product of German forum members investigation and developed fix.
  3. #53
    Rutland, Vermont
    Quote Originally Posted by Clearancediver View Post
    Well I had not considered it was intentional but yeah it does seem weird. I attributed it to the fact those wires were the longest. But I gotta pull the column anyway. It's not a sticky steering issue, it is a no power steering issue. EPS light comes on and shows codes for power steering reduction due to temperature. I know the steering module senses temperature and shuts down the power steering assist if it overheats. Mine shuts down immediately upon starting the car, even if it is cold. It will then be intermittent. The EPS light stays illuminated. I have not seen anyone with sticky steering say they have the EPS light on the dash.
  4. #54
    It wouldn't surprise me if those 4 broke just from vibrations and etc. Given their location they likely see the most stress from vibrations and the flexing/heat expansion of the unit. The "waviness" of the wires nearest the corners, especially on that left side, looks like the result of the areas being fatigued and stressed; especially when compared to the wires more in the middle which are all relatively straight. Perhaps there is some lateral movement from the motor's torque which transfers into this assembly and over time weakens, then breaks, the leads on the edges.
    It would be certainly interesting now to follow this up by dissecting a few more failed units to see if they fail in similar ways and perhaps also dissecting a good unit to see if those corner leads are cut.
    PRICE CUT on ALL FABRICS
  5. #55
    Rutland, Vermont
    Quote Originally Posted by BimmerBreaker View Post
    Agreed. And it’ll be good to compare with the one in the car now which I will definitely do once the weather changes. Would love to see if someone had exposed the board on a good one. Ima do some research.
  6. #56
    Oct 2012
    Victoria BC Canada
    I’m going to stay with deliberately disabled/cut. Just not possible to have the same wires break in four corners without having other wires being damaged via the same mechanism you propose.
  7. #57
    Rutland, Vermont
    It’s all conjecture until someone produces a photograph or some other evidence based proof.
  8. #58
    Rutland, Vermont
    This place is pretty beat.
    Anyway, still driving the car. Runs and drives great! The 2.5 seems to have plenty of power. Still shoulda swapped for a M62tu. Some dumb pics:
    Parked at a buddy’s place on the first green.
    Usually hang out in the garage. The resultant view.
  9. #59
    Not too late to M62 swap it now... They make kits for physical fitment and the wiring is very simple
  10. #60
    Rutland, Vermont
    Yeah this thread would be a lot cooler if I did that swap. The engine I had for it turned out to be a really good one too but is now in another E38 so would need to find one along with a 6-speed. Kinda bored with the car now so maybe need a new project such as that. Still need to fix the steering though I would convert to hydraulic in an M62 scenario.
    I think the biggest issue would be the exhaust, the fabrication of which would need to be farmed out due to the absence of welding skills in me.
  11. #61
    A Z4M exhaust would likely work just fine since the S54 made more power than the M62
    Not sure how the M exhaust fits on non-M's though...
  12. #62
    Rutland, Vermont
    I’d have to crawl underneath and take a look but it’d probably work. Maybe have to hybrid an E38/E39 front half with secondary cats to back half E85 Z4M.
    I’m running out of excuses .
  13. #63
    Oct 2021
    Toronto
    2008 Z4MC
    Wow, great build thread, someone really drove her into the ground, you've done fantastic work.
    I have pretty much the same thing to 2008 Z4MC, https://www.zpost.com/forums/showthread.php?t=1910373
    Mine wasn't in anywhere near the condition of yours but I replaced every wearable part anyway.
    Rutland, Vermont
    Quote Originally Posted by grannyknot View Post
    Mine was mainly cosmetic and some suspension so far. Yours is another level! Plus I would probably prefer a coupe. Not a big convertible guy, I feel pretty self conscious driving this thing around.
  15. #65
    IL
    2000 740i sport
    What a save! Great work!
  16. #66
    Rutland, Vermont
    Quote Originally Posted by purplecty View Post
    Thanks Purp! I’m a sucker for the downtrodden…
  1. Z4 E85,E86 z4 oem car cover for sale
    By Jamesbond740il in forum Z3,Z4,Z8 Classifieds
    Last Post: 06-14-2016, 05:58 PM
  2. Z4 E85,E86 FS. Z4 Roadster car cover
    By roseman in forum Z3,Z4,Z8 Classifieds
    Last Post: 07-31-2010, 09:18 AM
  3. Roadster Solutions Z4 NOAH car cover w/ Door Panels
    By ToddAnisman in forum Other Items
    Last Post: 06-30-2008, 12:59 AM
  4. TC Kline Z4 race car for sale
    By jimcheng75 in forum 3 series & Z Series
    Last Post: 12-20-2007, 05:09 PM
