For me the stock flywheel and M5 clutch is the way to go. For others, I've seen a lot of variation. Do what you think is best for you is what I think it comes down to.
Just like manual tranny fluid. I went stock and it seems to perform best of all the others I tried, redline, royal purple, etc. Same for the rear diff. Tried the same list of options, ended up back with stock and liking it most.
Sent from my SM-G975U using Tapatalk
Same thing that will make you smile will make you cry. Was that a piston?
If I had to do the clutch again, I might be wishy-washy on the Unicorn if $$ was a factor. If $$ is no object, then Unicorn all day. As for the pressure plate and disk, I'd do exactly the same, I like the setup. If you want revvy and don't mind the rattle, you could probably do a lightweight and this clutch setup and be in really good shape. I really doubt lightweight FW = faster car though, just revvier car. I'm having no problems rev matching with the Unicorn.
I'm a total bonehead for not doing them while I was under the car for 5 months. I remember looking at them 11 times and thinking "what are those? I'll have to research them". I think when I start the SC project, I'll pull the shroud and fan, then climb under and do the mounts, then get back to work under the hood. Should I do stockers or try to round up poly? I didn't see any poly on ECS, haven't checked FCP yet. My trans and diff mounts are poly already.
I ordered the stock corteco (SP?) ones from FCP, I couldn't find poly but I did find something similar to delrin, pretty much solid, that's race car stuff.
I don't know if anyone answered, but after a couple hundred miles, I'm liking this setup. Pedal effort isn't excessive (I don't notice it, local indy shop mentioned it though). I won't know until next year if it can keep up with real boost since the altitude has me nuetered to just a couple lbs right now, but ZF/Sachs claims something like 450 or 500 lb/ft which I'll never make, so I think I'll be good.
I wouldn't recommend whatever fluid I used in a DD though, 1st and 2nd are tough anywhere under 60 degrees. Once some heat gets into the trans though, all gears row nicely. Would probably be unusable in freezing weather.
